79 DANA 60 rear disc brake conversion
i picked up a DANA 60 rear axle out of a 79 f250 4x4 while i clean it up and paint it i want to convert to disc brakes my question is what kits are out there for this swap? i checked out this kit but not sure how good it is D60 Rear Disc Brake Kit anyone have this kit or know if it's any good are there better kits out there? the axle will be going in my 71 f250 4x4 crew cab
You can do the conversion much cheaper without the kit, using over the counter chevy parts from your local parts house.... https://www.ford-trucks.com/forums/8...sc-brakes.html
so will i be able to get the caliper bracket at autozone? or is that the only part i need to find online? if at autozone what application should i say its for to fit my 79 dana 60 axle? i want calipers without the parking brake as i will be using a e brake on the back of my trans
Originally Posted by crazed87bronco
(Post 10121585)
I always thought the DANA 60 was a 3" axle tube that website says the mounts are for a 3.125" am I mistaking? Is it really 3.125"
I still prefer my homemade weld on style ones! This way I could clock it to any position to be able to bleed all the air out for my application.
The price was right at free 99 https://www.ford-trucks.com/user_gal...id=207402&.jpg https://www.ford-trucks.com/user_gal...id=207400&.jpg |
(Post 10122591)
73 Ford guy I seen the pics you posted in the one lift thread great truck. the brackets that are in the link above bolt at the backing plate am I correct? Couldn't I spin the brackets to where I want them and weld them on instead of bolting them in place?
(Post 10122695)
(Post 10122695)
If you chew up ujoints due to extreme angle a cv shaft is a must! |
That is a great price for those brackets. I paid about $70 from Great Lakes on Ebay. Buy your soft lines from Rock Auto and save about 50%! on close outs.
http://i659.photobucket.com/albums/u...e/P1010434.jpg You might also want to think about installing an adjustable proportioning valve. http://i659.photobucket.com/albums/u...e/P1010430.jpg |
I did this to my 14FF, although the process and parts are almost the same. You will need:
D60 brackets chevy 3/4 Disc brake rotors, calipers and pads. I used brake hoses for a early 80s car, because they were only $10 a side and the truck ones were double. http://i161.photobucket.com/albums/t.../discbrake.jpg |
Originally Posted by F-250 restorer
(Post 10124564)
Originally Posted by 73 ford guy
(Post 10123628)
In your case if you had bolt on brackets I would slot the holes to where you need the caliper sitting then bolt and weld it. Just remember if you ever need to tilt your diff up towards your t case down the road for a cv driveshaft you will need to re locate the caliper so it will properly bleed and get the air out. I did both at once cv shaft, rotating up, then got an idea where the caliper needs to sit , so weld on style is nice..
you can tell them 1984 chevy K20, that would be a 10 bolt front (better calipers than d44) with 8 lug outers. I put mine the way I did because the spring interfered with any other indexing. Plus that would be the stock location of the front chevy.
