truck starts without key
my truck starts without the keys in it. is it hard to change the ingition switch?
I would love that!!! Just dont tell no one you dont trust.
But sounds like the lock cylinder is no good,the ignition switch is fine by you being able to start it minus the key. |
Ya it was fun for awhile till I was muddin and my friends would joy ride my truck while I was dirtbiking
What is your address ???
Originally Posted by lew52
(Post 10119634)
lew52, They were my thoughts too!!!!!!!!!!!!!!!!!:-partybud But really it is not that hard, best bet is to get a manual. And you live on what street now????????????????? I would lock your doors till you fix it. |
mine is the same way, but after a while the ignition screwed up so i had to put in a push button in. so now only i can start my truck lol
Originally Posted by ItsAFord55
(Post 10119446)
-Rod |
I believe its Mitchells manual that shows the best description on how to change the lock cylinder. The lock cylinder moves a rod that is connected to your ignition switch which is located on the top of the steering column below the dash board, two nuts to take off and replace the switch. you have to insert the rod into the groove in bottom of switch and into a hole in the switch. Plug the plug back into switch, check timing to make sure the lock cylinder will turn the vechicle on and off. then, tighten the nuts. all done. Just did mine yesterday. For some reason my heater fan stays on when i shut off the ignition,as do the turn signals and backup lites if in reverse.( manual tranmission). Gotta make sure i shut everything down or i come out and have a dead battery.
What White Max said. Its a known problem with these trucks. Mine did this for a couple of years. I finally plopped down the $16.00USD to buy a new cylinder. It literally is a 5 - 10 minute job. There is a hole underneath the ignition key cylinder. just put a skinny object (I used a torx screw driver) in the hole, turn the key while pulling out on the ignition key assembly. It might take a little doing, but ideally it pulls right out when you get a feel for it.
I highly recommend fixing it. The couple of times I let others borrow my truck; they accidentally left the ignition in the "ACC" position which caused the battery to drain. The cons of this is you will have a separate ignition key from your door key. I thought it would be a major inconvenience, but it actually has some advantages. You can have them "keyed" to be the same but it costs money. From a safety standpoint, there have been some accidents caused by this problem. Not too long ago a 5 year kid started his grandmother's truck and drove it into a swimming pool! |
I actually liked mine not needing a key. I was a FireFighter for 27 years. In the middle of the nite when my pager went off , I didn't have to look for keys. Just jump into my clothes , fire the old girl off and haul ass to the station. I had a 76 Nova that was the same way , it was mighty handy.
