Ford Truck Enthusiasts Forums
-   1997 - 2003 F150 (https://www.ford-trucks.com/forums/forum25/)
-   -   2001 F-150 vibration (https://www.ford-trucks.com/forums/1048167-2001-f-150-vibration.html)
big-papa 03-09-2011 04:39 PM
I have a problem with what feels like vibration to me and the people who ride in my truck.The question is i have no vibration at all from a stand still and acceleration but when I turn the vibration is there and only getting worse.It feels like it is coming from the rear of the truck but i could be wrong.So if you had this problem or know whats wrong i would appreciate any and all help. Thanks in advance
Richard
Scalemandave 03-09-2011 05:41 PM
If You have a Posi Rear & it does it on a turn from a start it sounds like the clutch pack grabbing in the rear. May just need gear oil changed & posi additive or could be clutch is bad. Just had mine done.
big-papa 03-09-2011 06:15 PM
not sure what clutch pack you mean is it the one in the trans or is there one in the rear end?
Scalemandave 03-09-2011 06:23 PM
If It's A studder in the rear when You make a hard turn,& it's a posi, it's the clutches in the rear. The posi additive availabe at autobone or pepboys may help. Like 6 bucks. Check the Vin sticker on the door jam for the code to see what rear you have.
big-papa 03-09-2011 07:28 PM
this is what i got from the door tag if it helps or not B6 — 3.73 limited slip (F-150, F-250)
big-papa 03-09-2011 07:30 PM
B6 — 3.73 limited slip (F-150, F-250) hope that helps so im guessing i do not have posi.
steve(ill) 03-09-2011 10:30 PM
FORDis not positrack... FORD is called limited slip or LS.. yes you have that. What you need to do is go to Auto Zone and get a 7 oz tube of friction modifier for gear lube. Crawl under the truck and take the 3/8 inch pipe plug out of the axle pumpkin just above the drive sahft center line on the drivers side. Put a hooked wire into the hole and see if the level is down 1/2 inch. IF so, just squirt in the addative. If not, suck oout 7 oz of oil with a tube and add the addative. Drive for 50 miles and you should be o.k. after that.
big-papa 03-09-2011 11:17 PM
ok i will try that and i'll let you know if it helps
