Dana 50 vs Dana 60?
So I've been trying to do some research of the difference, and pro's-con's. I know the D60 is heavier duty and has larger parts, and the D50 is kinda a beefed up D44. But I have not found anything that relates to my model of truck. Nor info on upgrading, I've only seen upgrade from D44 info.
I currently have a D50 that needs some tlc under my truck, probably needs the gears replaced, needs some u-bolts replaced, and some of the steerig bars also replaced. So I was thinking, why not replace it with a D60, but everyone up here seems to think their made of solid gold. $1200-2500, or my personal favorite $850 for just the carrier, no axles. The largest I plan to run is like 35-37's with like 4:10-4:56's. Would that put un-needed strain on the D50 to the point were it would break, and a D60 is the way to go, or would I be better served to just spend the couple hundred to rebuild my axle? Also lift kits, with the D50, do I go for stock F250 kits, or F350. As some depend on the axle, and they seem to forget my axle exists. |
all the info you need is here, from the pages of it i read through.
Front axles: Dana 50 vs 60 - Page 2 - Pirate4x4.Com Bulletin Board |
i did the swap, my D50 was worn out and looser than a cheap lady of the evening, i am a die hard solid alxe guy though. i found my 60 and a 10.25 Stearling rear for 650 for both. didnt need the rear but i thiugh what the hell for 650. it even had the right ratio. after the rebuild and including the axles i had about a grand in it total.
I paid 800 for dana 60 and 250 for 10.25 on craigslist after continuous days of searching. Don't see em for sale here to often so they are pretty rare
Man i feel lucky. I got my complete parts truck (86 f350 4x4) for 500. I will be swapping out both axles this spring to my Bronco. Still have to find a place to store all the parts i want to keep off her lol. I also have been searching for the last 2 yrs for a d60 for mine. All the yards around here wanted about $1000-1200 for a solid front. That didn/t include any of the hardware either.
i paid 900 for mine with dully hubs with i still need to sell
Folks around here seem to think they're made of gold also. Averaging around $800-$1,200. Lowest I've seen is $600.
10.25 rears go for $200-$400. A D50 could be rebuilt much cheaper than the purchase, rebuild, and installation of the D60. But if you're lifitng it, running big tires, probably managing the throttle with a heavy foot...sounds like a Dana 60 might be up your alley. I plan to run the standard F150 5 lug 44 TTB under the diesel in my 65/95 F150 Mutt until it blows up, shouldn't take long to pop that inner U-joint. :eek: By then, I'll have a Dana 50/10.25 setup ready to install. I've got a line on a D50/10.25 combo with 3.55 gears for $300. Compare that to the price of a 60/10.25. |
Originally Posted by kenpobuck
(Post 10058828)
I think the dana 50's a pretty good. They use the dana 60 outers, The dana 44 ttb hd case, and a bigger ring gear than the dana 44 and 44hd. I also believe they have more splines, I do know they corrected the major failure point on the dana 44's with the dana 50. My 91 has a dana 50 and it seems it has plowed all its life. Its still under the truck too.
only problem is those damn pivot bushings
Yeah the D50 is a half decent axle, I was thinking if I did get a D60, I'd hold onto it for a bronco/F150 bush truck. Something I want a good sturdy front axle, but if it ends up F.U.B.A.R. I'm not going to cry that that axle cost me $1000, and now I gotta drag the truck outa the bush to get it....
Wow really? 1200$-2500$?
If I'd knew that last year I would of bought that piece of crap F350 Diesel truck I went to see for parts. Was asking 700$ for the whole truck, 4x4 E4OD 1991! I would of sold the axles and made some profit! |
How do you know what front axle you have? Ive been trying to figure out if i have the 50 or 60 all day. the Id numbers are
4 10 ve8ta yc v610312-2 but thats not very much help for some reason. |
There worth that in scrap, never mind the axles.
Frank |
The Dana 60 is a solid axle.
The Dana 44 and 50 are Independent. You can clearly see the D50 here http://i607.photobucket.com/albums/t...John/059-1.jpg The D44 and 50 work on the exact same principals as the 2wd Twin I Beams. And the solid, well it's pretty obvious how they look. |
