Need VIN decoded
Looking at a truck. All that is listed is crewcab, diesel 4x4 and vin. I need to know what trans is in it.
1FTHW26F7VEC00523 Thanks ,Brad |
I may be wrong, but I don't think trans info is in a VIN...
Heres all the info a VIN decode gives.
World Manufacturer Identifier - 1st, 2nd, 3rd Positions: Manufacturer: Ford Motor Company, USA Make: Ford Vehicle Type: Truck (Completed Vehicle) Brake Type and GVWR Class - 4th Position: Brake System: • Hydraulic brake system, Class G, GVWR 8,501-9,000 pounds, None Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions: Line Series: F-Series - F250 Chassis Type: 4x4 Body Type: Pickup - Crew Cab Engine Type - 8th Position: Engine: 7.3(445cid) DI-Turbo Cylinders: V-8 Fuel Type: Diesel Horse Power: TBD Model Year - 10th Position: Model Year: 1997 Assembly Plant - 11th Position: Assembly Plant: Kentucky Truck: Jefferson County, Kentucky Production Sequence Number - 12th - 17th: Sequence Number: C00523 |
The trans/axle/weight info will be given on the vehicle information label that can be found on the drivers side door jamb.
regards rikard Good to see the 21 Motorcraft win the 500 |
You need the trans code from the door sticker as already stated. `97 was the last year for the E4OD, so if auto, it is probably that.
All right. Thanks guys. I found a truck on line and i cant call till at least 8am monday, i just wanted to know what trans it had
I found this web site and found out EVERYTHING
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, and Mazda Trucks VIN Decoder And here is the info from the vin EGAMK 4.09 EGAMD 4.10 TR0RK 5 SPD M/T Z/F S5-420 EJAJF 6250 LB(2834 KG) REAR AXLE ASY EJAJJ 6340 LB(2876 KG) REAR AXLE ASSY D2XE2 7.0 X 16" FORGED ALUM WHL IBAAX AM/FM STEREO WITH SINGLE CD PLAYER AND SIX SPEAKERS JCBAB AMBIENT LIGHTING EM0C0 CALIFORNIA REQUIREMENTS BLDAB CHROME-PLATED AAMAB CONVENIENCE GROUP D3MAD CONVENTIONAL SPARE TIRE EJ1AB DECAL-4X4 PICKUP BOX BSDAD DRIVER POWER MIRROR EGLAB FORD/VISTEON AXLE VENDOR CLFAE FRONT BUMPER-STEEL-CHROMED CLVAB FRT LICENSE PLATE BRKT/HOLDER DEBAF IMMERSION HEATER-ENGINE AAGA1 KENTUCKY TRUCK PLANT BUILD PNYCE LIGHT OPAL EGJAC LIMITED SLIP REAR AXLE BMLAE LOWER B/S MLDG D3JUE LT235/85R-16E BSW A-T TYRES FMLAB MAN TRANSFER CASE AND MAN HUBS AC0B0 MANUAL AIR CONDITIONER 000YD MEDIUM OPAL GREY PNFJA MEDIUM TOREADOR RED EN0DS NAVISTAR 7.3L OHV DI TC V8 DSL F7THB NOT DEFINED BSFAD PASS POWER CONVEX MIRROR B2GAE PRIVACY GLASS CLMAE REAR BUMPER-STEEL STEP-CHROMED BYBAE SECOND ROW BENCH SEAT (3 PASS) FMNAB SKID PLATES B3HAD SLIDING REAR WINDOW GTDAB SPEED CONTROL A9CAB STYLESIDE BOX - STL INNER/OUTER HGAAB TACHOMETER BYCAB THIRD ROW BENCH SEAT GRAAC TILT STEERING WHEEL BYDAE WITH 4TH ROW BENCH SEAT (4 PASS.) GBCAB WITH AUXILIARY FUEL TANK CJDAB WITH BODY TU-TONE PAINT BLMAB WITH BRIGHT HEADLAMP MOULDING EGLAC WITH DANA AXLE DWCAB WITH HANDLING PACKAGE BHEAB WITH NOISE INSULATION PACK DAAAD WITH SUPER ENGINE COOLING SYSTEM AALAA WITHOUT SPECIAL EQUIPMENT PACKAGE AAAAD XLT VERSION |
Great link! :-drink
Great site thx alot
attempting to determine if my vehicle originally came with a keyless entry option.
1FTHX26G5NKB93370 tHANKS |
