Stock Exhaust Size?
I'm sure this is common knowledge, but I quick search didn't turn anything up.
What's the standard exhaust pipe size? My specific interest is a 96 f150 with a 351. But I'm also curious to know if 302's run the same size and if it varies on heavier trucks. |
I think they were all 2.5 inchs.
Take a look at Walker Exhaust Solutions From The Industry Leader. You can tell the OD by checking the size of clamp used.
I believe that your exhaust OD is 2 and one quarter inch before the muffler and then 2 inch tail pipe for both tail pipes. The 302 uses 2 1/4 through out -including the single tail pipe/ The 351 has twin tail pipes of 2 inch OD---the 300 and 302 uses a single 2 1/4 inch OD tail pipe. |
good info here. I would like to add that the 351 3/4 and 1 ton trucks have an exhaust resembling what you describe. both 1/2 tons I have owned with 351's only had a single tail pipe.
That most likely means it's the same as the 300/302 trucks. thank you |
My '92 F350 w/5.8L engine used that hokey dual tailpipe setup. The factory y-pipe is pretty neat, dual pipes that terminate into an oval flange. But the factory single converter is a monster and $$pricey$$
Originally Posted by rla2005
(Post 9996871)
I replaced the factory exhaust with a Bassani y-pipe, Magnaflow high-flow converter and muffler then finished it off with a Dynomax 3" single tailpipe about 2 years ago.
I did find a previous owner had hollowed out that monster converter. The entire exhaust was ready to fall off the truck when I replaced it. In fact the pipe leading out of the converter fell apart a few days before my parts arrived. |
Originally Posted by skyfox10
(Post 9996803)
That most likely means it's the same as the 300/302 trucks. thank you Even the Bronco that had the factory 351 had dual tail pipes from the factory. And there are no 3/4 ton Broncos. |
Originally Posted by phoneman91
(Post 9998896)
Did your 351 1/2 tons have the factory exhaust tail pipe and muffler? Are you sure that they weren't aftermarket. It is my understanding that even the one half tons got dual exhaust pipes from the factory. And that many of them were replaced with single exhaust mufflers and tail pipes because it was cheaper.
Even the Bronco that had the factory 351 had dual tail pipes from the factory. And there are no 3/4 ton Broncos. Also, here is a diagram of a 96 bronco with 351 http://www.supermotors.net/getfile/7...aust5.8l96.jpg |
i see the 302 uses a 2 and 1/4" pipe throughout but is that OD or ID?
im wanting to take off everything from the first cat back and put in a single pipe with a dumped muffler and need to know what im looking for. |
Originally Posted by xc4jokestomper
(Post 10120404)
Between cat and muffler?
(Post 10005286)
I'm 100% sure, I went with my dad to pick up the 95 when it was brand new off the lot. Also, I've never seen a bronco like that before...
The 351 Broncos had a single pipe like stated above.
Originally Posted by 85idipower
(Post 15777509)
What is the thing in between the cat and the muffler? Is it just a heat shield or what?
that is the 2nd part of the cat system, it also has the ceramic honeycomb in it to catch more pollutants, the first one misses
https://cimg5.ibsrv.net/gimg/www.for...ceea94b1de.png |
