Engine Pics and accessory brackets
Let's see your engine and accessory pics... Here's mine the only acc bracket I have right now is a drv side low mount Alt bracket... I will be moving it up because I will be adding AC and power steering sometime...
https://www.ford-trucks.com/forums/p...ictureid=59563 |
This is were I'm at with brackets on the engine. I'm designing and fabricating my own for the steering pump.
http://i822.photobucket.com/albums/z...1949f47005.jpg http://i822.photobucket.com/albums/z...1949f47003.jpg http://i822.photobucket.com/albums/z...sinstalled.jpg |
[quote=Mervy49;9988363]This is were I'm at with brackets on the engine. I'm designing and fabricating my own for the steering pump.
http://i822.photobucket.com/albums/z...1949f47005.jpg [quote] Mervy looks nice! are you going to add a braket to tie the three long spacers together to make it easier to install.... shouldn't have any problem of the mount moving when it's tighten down 4 mounting bolts... Keep up the great work... BBF? What box/rack are you using? |
here is mine
1955 f100 1991 5.0ho I'm running a '72 chevelle front clip with power steering and a saginaw pump [IMG]http://i53.tinypic.com/11t4lr5.jpg[/IMG]. [IMG]http://i53.tinypic.com/2e1u3q1.jpg[/IMG] [IMG]http://i56.tinypic.com/2ewp451.jpg[/IMG] Joe |
Here's mine;
https://www.ford-trucks.com/user_gal...176131.520.390 Stock Caddy accessories, alternator and power steering pump Bobby |
Originally Posted by bobbytnm
(Post 9991529)
Here's mine;
https://www.ford-trucks.com/user_gal...176131.520.390 Stock Caddy accessories, alternator and power steering pump Bobby where did you find that Cady/Olds air cleaner? love the look and great work on the valve covers |
(Post 9991529)
Here's mine;
Moe,
I bought it off of Ebay, they are getting kind of pricey but sometimes you can find them that aren't listed right. If you search for them on ebay keep in mind that Packard and Oldsmobile also used them. I think they were used from roughly 1953 to 55 or so. I think you can get a new repop from Speedway motors for less than $200 Thanks for the compliment on the valve covers....I sort of made them by combining the tops of mid 50's valve covers with later model valve covers. Iwanaflattie, Thanks for the compliment. I ended up using Ford blue on the engine because none of the local parts stores had Caddy blue in stock. Since its sitting in a Ford truck it all works out ok....lol Bobby |
(Post 10002656)
Moe,
I bought it off of Ebay, they are getting kind of pricey but sometimes you can find them that aren't listed right. If you search for them on ebay keep in mind that Packard and Oldsmobile also used them. I think they were used from roughly 1953 to 55 or so. I think you can get a new repop from Speedway motors for less than $200 Bobby |
[quote=Moe Craig;9988412][quote=Mervy49;9988363]This is were I'm at with brackets on the engine. I'm designing and fabricating my own for the steering pump.
http://i822.photobucket.com/albums/z...1949f47005.jpg Mervy looks nice! are you going to add a braket to tie the three long spacers together to make it easier to install.... shouldn't have any problem of the mount moving when it's tighten down 4 mounting bolts... Keep up the great work... BBF? What box/rack are you using? |
https://www.ford-trucks.com/forums/p...ictureid=61569
I changed over to a serpetine belt . I got at a local garage we believe the engine came out of 80's mercury. It should save me some room and it makes it easy to add air and power steering and was less than 100$ |
HERES MINE
At the time of the picture I still had to put on the Saginaw PS pump install fuel line and some other items. Bobby I dig that air cleaner where did you get that? https://www.ford-trucks.com/forums/p...ictureid=60183 |
agronomistont, I was thinking about a Serpintine Belt system... But my heads aren't drilled for it...
Ron, Nice motor... |
Originally Posted by skuzzel_butt
(Post 9989728)
here is mine
1955 f100 1991 5.0ho I'm running a '72 chevelle front clip with power steering and a saginaw pump [IMG]http://i53.tinypic.com/11t4lr5.jpg[/IMG]. [IMG]http://i53.tinypic.com/2e1u3q1.jpg[/IMG] [IMG]http://i56.tinypic.com/2ewp451.jpg[/IMG] Joe Joe are you running a stock fan ( non electric) with a custom housing from the radiator? If so where did you get that made at?? Mike |
1 Attachment(s)
I was tired of chasing down pulleys and brackets...went with the kit from Vintage Air.
