Fuel FIlter Change - in the Information Center
Hello all - I am curious as to whether or not anyone has actually received the change fuel filter message in the DIC or is everyone just changing it for there own piece of mind? I have over 22k on my clock and not a message to change the fuel filter yet - Just wondering if anyone has actually seen the message - Maybe mine isn't working, or maybe it's not time yet - Just checking...
Good question..I just went over 22000 miles.
Originally Posted by rickatic
(Post 9978512)
Personally, I don't want to wait on the computer for the fuel. The computer doesn't know (that I'm aware of) what quality of diesel you are feeding it. So far I have not had any water draining my DFCM monthly but that doesn't mean there hasn't been small objects in the fuel. Attached is what Ford says. https://www.ford-trucks.com/forums/p...ictureid=60842 |
Is there only one fuel filter on the 6.7L. Are they easier to change than the 6.0L? Where is it located? Under the hood or on the frame rail? Do you need any special tools?
There are no video's out on YouTube.com showing how to change. Maybe Epic can create one???? |
Originally Posted by Shepardsonp
(Post 9995747)
There are no video's out on YouTube.com showing how to change. Maybe Epic can create one???? Looks like they are easier to get to though. |
Funny thing, I got a fuel filter message at about 10500 miles. Called a dealer while I was in SoCal, they told me to just reset the message and go by the third oil change paradigm.
jammer :cool: |
fuel filter change
Hi Guys
Change my filter today, very easy The large filter is a spin off filter carrier with the filter element in it, drain the filter in a pail takes about 5 minutes to do that, use a 1 1/4 in socket to turn it off, change the element and big O ring and spin it back on, it has a "stop" so you can't go wrong turning it in. The top filter is as easy, lossen a 7 mil nut that holds the filter tight, the green keeper on the left line goes ina downward direction, just pinch it and it moves down, the right one has a white push tab, push it down with your finger or use a screw driver, then grab the line and move the fuel line towards the filter and and then pull back and it will release. There is a bit of fuel spilled so place some paper towel under the lines prior to removing the lines. The lines go back on as easy. Cycle the key a few times to refill the filters. I would do this with a cool motor. This is not ment to be a tutorial, but just to show how easy it can be. Any ways guys this was my first time and I did it without incident :-X25 |
I have not gotten the message. Currently at about 24K on filters. Dealer changed them out at 10K for no reason other than I think the diesel tech just wanted to do it, which I'm good with at the first 10K.
I watched him do it. Very easy as long as you pay attention to put everything back the way it was (o rings and such). |
I dont know - I still have the original filters and no indicator to change yet - I wonder if the flashes reset the minder? It didn't reset the coolant minder as it is on now..
Interesting... looks like they addressed the big issues by switching to a Vertically oriented fuel module. Did anyone get a look at what it is? It use to be a Parker-Hannifin unit. How much did the 2 filter set cost? I always thought the old HFCM was a doozie, and the VFCM was a much better unit. Does it have a fuel heater built in?
Reset Message?
Hi All,
I'm new to the forum... I finally did receive the "fuel filter change required" message at 21,500 miles. I replaced both fuel filters (they didn't look bad), but I STILL have the "fuel filter change required" message... Does anyone know how to reset it? The reset oil filter was easy - this one, not so much... I heard on other trucks you turn on the truck (but don't start), wait 5 seconds, then press the gas and brake for 10 seconds. This didn't work for me. Any help would be appreciated... Thanks, Bill |
Originally Posted by Bmacs
(Post 13039236)
Hi All,
RM2012F350,
Do you have a little more detail than that? I've been through the menus. There is an "oil life reset" - but no "fuel filter reset" Have you reset the fuel filter through the menus yourself? Thanks, Bill |
Its in the same general area, not same place as oil reset, but same place as the coolant test reset.
