Replacing Universal Joints
Hi, we have two 99 F150's where I work and they both need new u-joints. One is 4X4 and the other is two wheel drive. Both are automatic trans, 4.6L
I know how to remove the driveshaft from the vehicle, but have never changed u-joints. Is there any special tool or technique required to drive them out? Thanks. |
Originally Posted by Justin's Green Truck
(Post 9975402)
I know how to remove the driveshaft from the vehicle, but have never changed u-joints. Is there any special tool or technique required to drive them out? Thanks. Don't forget before you remove the drive shafts to use a marker to mark the relation of the shaft and the slip yoke(they are balanced) Oh yea, a little PB helps too. http://www.harborfreight.com/media/c.../image_569.jpg |
I like to take out the drive shaft then take it to a driveline shop. They will replace the joints and balance for a very small fee. saves the headache and then they are balanced. The picture shown is a ball joint press. It should work if you set it up right..
Originally Posted by N832
(Post 9976416)
I was refering to marking the Drive Shaft/Differential Pinion Flange before you remove the bolts holding both together so they get reinstalled in the same exact position that you removed them. These marks ensure that the drive shafts dynamic balance will be restored when the driveshaft is installed again. |
