Crank.. No start.. P1663 FDCS Circuit Failure
I know there is tons of good info here, and I am in the process of searching as we go, but I am in a bit of a time crunch!
The ol project truck got wired up and new batteries for fire up today! This is my 94/97 hybrid, LOL! For all purposes, its a 97 F250HD 7.3 Auto 4x4 for trouble shooting.. I got everything hooked up, checked wiring and went to start it with no luck. Here is what has happened:
Any ideas? I got get this truck up and going asap, or its going into storage for a long time, as I am moving at the end of this week, and will have to leave it behind to be picked up another year. Thank you!! |
What is the FDCS? Isn't this your SD motor in the 97? I really am not any help but the GPR shouldn't be getting hot. It should be a timed event. WAG, wiring.
I would take the chip out first of all just to eliminate that. Fdcs is fuel delivery command signal. with some limited searching I came up with a possible faulty pcm or idm. Canyou swap in a different one to try? Here's a little of what I found
Fuel Delivery Command Signal (FDCS) |
Is the fuel filter good? Is the FPR screen clear? Oil in the HPOP at the proper level?
I'm assuming you checked these already, but I had to ask just to make sure. I'm leaning towards the advice Muktown gave. Pull the chip and see what happens. |
T1 DIAGNOSTIC TROUBLE CODE (DTC) P1663 — FDCS CIRCUIT FAILURE
DTC 1663 indicated that the PCM has detected a failure on the FDCS line. Possible causes: Open/short in FDCS circuit Non-powered IDM IDM PCM Check for other codes. Key on, engine off. Perform KOEO On-Demand Self Test and retrieve Continuous DTCs If you pull the chip , make sure the key is in your pocket... |
Craig: Brand new filters and lubes! New O-rings, gaskets, belts and hoses!
Rick and Justin: Not sure I can pull the chip and all will work. I dont have the key, as I am not the one that originally put this chip in. If I pull the chip, will I kill the memory? Glenn: I will check on that WAG wiring! Isnt there supposed to be a wire that runs to the fuel bowl that has an inline fuse? If so, where does that wire originate from? |
Make sure the key is off. Then just pull the chip out. Then the programming will just go back to the stock PCM programming. If the chip is bad the truck should start. Either way I would leave the chip out until its up and running.
Originally Posted by tjbeggs
(Post 9968140)
As for an update.. What a nightmare!!! I went to a variety of autoparts shops looking to get a new computer, after seeing brand new they are around $130. Problem being, order and shipping time. Many of them will get it to me next week.. Not working on my schedule. I had serious issues with the rocket scientists at Autozone.. They wouldnt get me any info unless I provided a VIN. Problem being.. the engine and computer are from the donor truck, which has been recylced into a park bench or something, along with all the paperwork! So I went to the dealership here. I originally hit the first parts guy up for the computer.. $580.. I think not! I told I needed a moment to think over that price.. he walked away from the counter leaving me to wonder.. I asked to speak to the head service tech supervisor here. The service manager was really patient and helpful with me. She went over the codes and process I went through to trouble shoot the problem. The final code (P1663) I told her about. She went online through the Ford Service Tech manuals and info, found that its the IDM that has failed. Good news.. TJ's advice with the chip out can be tested with some promise, and I will need to get a new IDM. I am not going through the dealership on that one.. $1140 is what they want for one, and it takes 2 weeks to ship. I have another source down here I am going to tap and see where it goes from there.. I will keep ya'll updated! Thank you all for the help!!! |
More info..
Thought I would share the video of its first start too..
[IMG]******** width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Q2l4Te9qs6M?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Q2l4Te9qs6M?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed>*********>[/IMG] |
Chris, seems to me that I might have an extra one. When I did the 140v mod I got an extra in case I screwed up the IDM. I'll look in the bottom of my tool box.
Ok Glenn! I appreciate it! By any chance, an extra PCM too, just in case, LOL!
Chris, I do have an extra, extra. Want me to ship it to you? PCM?? Ya, and there is almost a full moon out too! LOL
Thank you Glenn.. I will PM about it all..
Good news UPDATE: The IDM was bad! I found a loaner, put it in.. She runs soooooo Nicely!!! |
Way to go!
