tips and advice for a new guy needed
For a few years I have wanted to be able to make my own bio. Now the first issue comes to mind is...will the 6.0 run on it and not go to pieces?. I had a 7.3 and it ran great on pump bio. I have always liked the fuel meister 2 system, how good is this system? pro and cons? do I really save any money doing it?
Originally Posted by guthrie&co
(Post 9938024)
What is wrong with it being of plastic?
My concern lies in the fact that if there was ever a fire, a bad problem would become much worse. Imagine a processor full of methanol laden hot oil, gushing out the side of a molten plastic cone bottom tank processor which ruptured due to a small fire which started from an electrical short from a chafed cord which ignited some spilled methanol on the ground. Suddenly the fire spreads as far as the oil is traveling.
My processor is made from a steel 55 gallon drum, and while a similar scenario with a small fire could just as easily occur, at least it would not be compounded with a lot of additional fuel spreading everywhere. I am always within 50 feet of my processor whenever I am reacting a batch anyway. The whole process of making biodiesel involves plenty of risk as it is. Why add another unsafe component? |
Search the web. There are lots of stories of plastic tanks catching fire. My whole system is steel only, no plastic tanks, and all steel piping. We had a bio fire here in Oregon a couple of years ago that started with a short in one of those HF water pumps that caused a small fire and melted a hole in his cone bottom tank and burnt the guys whole house down. Safety first!!!!
I've got a 100k on a 6.0 running mostly b100 and lost one injector at 200k. My testing of if the 6.0 will run b100 is complete in my opinion. It will. 200k miles and I've lost the same or less amount of injectors as somebody running D2 at 200k.
And plastic reactors suck or plastic anything having to do with making bio for that matter. Stainless tanks and tig welded stainless plumbing is the way to go. |
(First time on a forum) I Hope this is the right place to post. I live in Canada and drive an 08 f350 super duty diesel. Ive been interested in making my own diesel and learning the process. But im not sure where to start. Please help.
Welcome to the forum! Do lots of reading, and see if you can find a good source of oil first. Next look up the "Dr. Pepper method" and make a small batch just to see how the process goes. Lots of good info on this forum to help you get started.
Ive been making my own for over three years and have no problems. I made the "appleseed processor" from a water heater. Still working great. My only advice is instead of water washing the bio, use the dry wash method with wood chips. I think the bio is cleaner, much less hands on time, and it will save money by not using any water or electricty to dry it. I wish I would have done this from the begining.
