Painting interior trim pieces thread :)
Well as you all may know i am doing a ton of things to the exterior/motor/drive train so i figured i will do some updating on the interior as well :) Its easy to do, cheap and can make a big difference. I will first be doing the actually trim pieces, awhile back one broke and had to replace it and i dont really like the stock coloring on them. I will be painting them metallic silver to match the metallic silver pin striping on the outside of the truck. Heres what i will be using...
- Rost-oleum Painters Touch Ultra Cover Primer - Rost-oleum Painters Touch Ultra Cover Metallic aluminum - 600 grit wet sand paper - Acholol wipes In order to pop off the trim pieces i used a knife, do NOT force them off or you will break the clips. Slightly pry upwards with the knife and work your way down the trim piece. The ones on the doors are metal so are more tricky well the plastic ones pop off really easy. I will also be doing the grills of the speakers, the plastic covering around the gauges and a few other little things after i finish this little project still not sure if i want to paint them silver or go with a gloss black. I will be adding pictures as i go :-jammin http://i166.photobucket.com/albums/u...Photo-0023.jpg http://i166.photobucket.com/albums/u...Photo-0022.jpg |
Just finished wet sanding everything, then wiped everything down with acholol pads to get any of the dirt off to make the paint apply better without any little dirt specs in it. The black piece that has the XL on it was rough unlike the other ones that were smooth, i sanded it down so it is smooth like the rest with 600 grit. I should have done it with 320 grit then finished with 600 to smooth it out but alittle extra elbow grease never hurts anything... Be very careful with the 2 metal trim pieces they bend very easily and are a pain to bend back. When you wet sand the smooth pieces you dont need to apply much pressure because you the surface is already smooth you just need to get that clear coating on it off. After the second coat of primer i will post up pictures.
Some pictures after 2 coats of primer...
http://i166.photobucket.com/albums/u...Photo-0024.jpg http://i166.photobucket.com/albums/u...Photo-0025.jpg now for two coats of the metallic silver :) |
lookin good heres mine
https://www.ford-trucks.com/user_gal...id=228994&.jpg |
Originally Posted by rockin300
(Post 9929696)
yep thats what i did to and it went from there
(Post 9929730)
no not right now but i know im doin the seats next and the guage cover
This is 2 coats of primer and 2 coats of paint later :) one piece is still drying which is why it is not in this picture but i think i will end up painting them gloss black along with everything else (gauge cover, plastic by power windows, vents, and a few other things i am probably forgetting) It came out well, and if you plan on doing this even though it says it will dry in 30 mins give it a good hour in between coats just to make sure. I will have to pick up some gloss black later today and will post up pictures either tonight or Monday.
http://i166.photobucket.com/albums/u...Photo-0026.jpg |
Originally Posted by 93f250tn
(Post 9929722)
I like the headliner! i was thinking about doing something like that with some mossy oak camo sense i will be getting mossy oak seat covers and bench seat cover :0 I am still debating on weather to paint the speaker grill covers, gauge cover, and a few other things this metallic silver or gloss black :-X01 i guess when i put these in the truck this morning ill see how it looks and go from there :)
Before,
http://i618.photobucket.com/albums/t...a1/Dash002.jpg After, http://i618.photobucket.com/albums/t...a1/Dash003.jpg Also did the roof trim to break up the red... http://i618.photobucket.com/albums/t.../021009019.jpg |
How do you plan on putting the trim back on the door panels since you broke the clips that hold them on?
The trim looks nice. Where can you get the clips to hold them in? One of mine is missing.
Originally Posted by Diesel_Brad
(Post 9930468)
(Post 9930468)
