firewall crack in engine comparment
88 f250 5.0 4x4 5 speed
i noticed the plate in the engine compartment around the master cylinder seems to have detached from the firewall. the clutch pedal wont return to the top of its stroke. i checked the clutch rod and bushing both are still ok. when i press the clutch i can see the plate get pushed even further away from the firewall. do these reinforcement kits correct the plate detachment in the engine compartment? can i weld the plate back to the firewall?? someone who had dealt with this before please help!!!! <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"> |
This used to be a common problem, and Ford made a firewall repair kit for them, BUT-they're now discontinued from FoMoCo. Possibly available from an aftermarket source, or you may have to make something on your own.
ive done some research on the kits from ford but i can find any information on the big kit, just the small kit.
do these kits install from inside the cab or on the outside? with the plate being detached in the engine compartment would the much cheaper small kit be enough to fix my problem or would it require the bigger kit?? <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"> |
Click on the link below which describes both the small plate and large plate repair.
F150 clutch master cylander braket seperation - FixYa (To install the small reinforcement bracket). From inside the cab you remove the two nuts holding the clutch master cylinder to the plate that is pulling away from the firewall. Install the bracket over the two studs of the clutch master cylinder and reinstall the two nuts. The bracket clamps the under the hood plate the clutch master cylinder is attached to, to the firewall. This repair works as long as the firewall has no major cracks. This is a picture of the small reinforcement bracket. http://i135.photobucket.com/albums/q...orcement-2.jpg |
i think ill try to buy the small bracket and see where that takes me.
so the correct part number for the small bracket that is pictured in the last post is e3tz-7k509-a ? <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"> |
The small bracket is $5.00 e8tz7k509a
The doubler kit is $170.00 e3tz7k509b The repair kits are over twenty years old so Ford may no longer sell them. |
