hydraulic clutch fluid?
what to use here? some light hydraulic oil or blake fluid or ??
the MG and Triumph (brit) cars used mineral oil IIRC. |
brake fluid. dont know what your driving tho
Brake fluid. Mineral oil sounds like trouble waiting to happen.
In fact it might say right on the cap what it takes. |
you're right I should have specd for my '86 F250
the brit cars are all I've owned previously that had juice clutch. thanks all. |
Just use brake fluid. I have noticed at work now we sell a bottle that looks like brake fluid that says hydraulic clutch fluid. I'm sure someone is making money from relabeling a bottle of brake fluid.
yep, the screw cap does indeed state dot 3 brake fluid - should have taken a peek.
Oh, trust me, it is on the shelf labeled as hydraulic clutch fluid, and some are adamant about getting it, even though I tell them it is the same thing...
Where do you check your hydraulic clutch fluid at on a 92 Ford 350 diesel?
Originally Posted by ValWood81
(Post 20488082)
It's my opinion this design of slave cylinder is poor and apt to fail sooner than it should. There should be a bleed fitting at the base to flush any accumulation of water and saturated/discolored fluid. If I ever change mine again I will install it.
