Oil in Air Charge Cooler? Is that ok?
I noticed when I pulled off the air charge cooler hose to install my new Gillette Diesel fuel pressure spring that there was oil in the air charge cooler. Is that ok? or is it something I should be worried about. As a side note, I recently installed an Amsoil bypass engine oil filter.
<img src="http://img25.imageshack.us/img25/7135/img0438hx.jpg" alt="Image Hosted by ImageShack.us"/><br/>By <a target="_new" href="http://profile.imageshack.us/user/live2snowboard">live2snowboard</a> at 2011-01-15 |
A little bit of oil is normal from the Crankcase Ventilation system.
But if you find large amounts of oil.. not normal. |
The gillette spring will put your fuel pressure over the recommended max value of 75 psig. It could cause injector o-rings to leak. The upgraded factory fuel pressure regulator spring is what you need.
wstone, What is the hose that is coming off your oil filter lid for?
I would assume oil press.
That's his oil bypass filter hose.
Originally Posted by 69cj
(Post 9828809)
by pass filter. why? what is the benefit?
Didn't notice the filter out in the north forty. My boo-boo.
He has another thread with a different pic. Shows how they both fit in there.
Originally Posted by bismic
(Post 9828765)
Thanks |
Regulator kit part # 3C3Z-9T517-AG. I think you can get it for around $50.
I tried the Gillete spring and my fuel pressure went to 100 psig. I got it out of there immediately. Lots of similar stories. |
I've also got the GDS spring and have been running it for about 2 years now, no problems with the injectors yet. But Bismic is right that it will jump the fuel pressure up there above the recomended pressure.
Oil in IC system is normal due to the CCV as stated above. |
Originally Posted by hubler13f
(Post 9830908)
