How to bleed
I am servicing and 2008 Ford 6.4 diesel. Does anyone know how to bleed the air from fuel system after a filter change?
did you cycle the key to just the on position, listen for the fuel pump to come on.
Wait at least 30 seconds then shut key off and repeat. do this at least 6 times and then it should start. If not then verify that you have both fuel filters on completely. Be care of the caps. There are torque specs on them. If that does not work then you could always check the fuel cutoff switch to ensure it it no tripped. |
Based just on the title of the thread, I was going to suggest replacing the serpentine belt. I usually manage to let at least a little blood every time I play with that.....
I am learning and wear mechanics' gloves on a more regular basis. |
Where is the fuel cut off switch on 2008 6.4
How do you bleed the system after replacing the fuel lines on a 2008 6.4
