Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum41/)
-   -   1953 F100 (First Project) (http://www.ford-trucks.com/forums/1028885-1953-f100-first-project.html)
michaelmilburn 01-12-2011 11:51 PM
I recently purchased a 1953 F100 with a 302 Motor( will confirm this weekend once engine is washed down to find numbers)
It's the typcial project truck, paint, body has holes that need to be filled, suspension is stock, tires are from a low rider (added sex appeal), interior is all down to bare metal with only one small 3" by 2" spot of rust, bed has no wood but has all the metal strips etc etc
I am looking to this community for some help for a new kid working on his first truck. I'm looking to do all the work myself in my garage or as much as I can physically do. I'm in no rush to do this but i'd like to have near completion by next christmas so I could pass to this off to my father for Christmas.
Problems that are visible are the paint is faded, windows need to be replaced, the rims have to go soon lol but will do for now.
Does anyone know of a good book or personal experience on leveling the bed? When you look at the bed from behind it's off centered it's leaning more to the right and not even at all.
When I pick her up this weekend I will post pictures so everyone can see and then get some advice if you have any.
Mr. M-
kenjh 01-13-2011 12:02 AM
congratulations on your new truck..looking forward to seeing your pictures..I am learning after 40 plus years of pulling wrenches..start with a list and figger out what you need and want,,2 very different things..is it a runner? will it stop?you can get kit's for the bed with all the bolts and instructions ..mine has concreat leveling...it's a canadian thing!!if it not square or level start at the frame and check from there..for blocks and spacers..for me it's trial and terror...and learn by surprise...all good!!
carnut122 01-13-2011 12:06 AM
Mine leaned too; it was a bent frame. Welcome aboard!
michaelmilburn 01-13-2011 12:09 AM
I'm going to add photos to the thread in a few min's so take a look at the fun I've got myself into
michaelmilburn 01-13-2011 12:23 AM
Truck
http://www.ford-trucks.com/user_gall...239023.520.390
Notice the bed leaning to the right, any idea's on how to adjust?
http://www.ford-trucks.com/user_gall...239024.520.390
leadsled56 01-13-2011 04:17 AM
unbolt that corner and throw a couple of washers in between the frame and the bed. if you want to dive a little deeper then check the rear bed crossmember. one side could be crushed a little. just to give a little advise, don't just tear it completly apart. be extremely anal when labeling things. use zip ties and zip lock bags. mark everything. just because you know what this weird looking thing you just pulled off is right now doesn't mean 8 months from now you will remember. I work as a helicopter mechanic by trade. this is how we do it with those too. useing this method, I have been able to put aircraft back together even 3 years after we took it apart. also start out with a plan. even if its a little vague. do you want all original or full custom? personally I like to start with the drive train first and then do the body later. the reason why is because it would suck to complete the body and paint then cut parts of it to fit a different suspension or something. what you could do if you had the room (not saying you do) is set up a spare frame the way you want while you drive your truck. once it's ready you can swap your body onto the frame.
carnut122 01-13-2011 11:10 AM
Yeh... what leadsled56 said. BTW your truck seems to be in fairly decent shape! I wish mine started out that nicely.
52 Merc 01-13-2011 11:11 AM
Quote:
Your truck bed sits on 4 crossmembers that bolt to your fame rails. For your bed to be that crooked, you either have bent frame rails or bent or rotted crossmembers. You'll have to crawl underneath and do some investigating to find the problem before deciding on a 'cure.' The good news is, the crossmembers are readily available and not too expensive, if you need to replace one or more.
Take a look and let us know what you find. :)
michaelmilburn 01-14-2011 03:56 PM
I will keep you informed on what i find.
Now comes a fun question of what's really wrong with this truck.
Aside from mickey mouse wiring and most likely a dead battery, i know the headers are old, carb is FUBAR, intake is stock, it has garden hose's attached to somethings. I plan to replace all the fuel line's, hoses wiring etc.
Now here's the quesiton. It takes awhile for it to start, i have to put fuel in the carb to get it going, when it starts it starts fine it runs then it just stops.
You start it again and it may stall one or two more times then get going. I went for a drive when i first bought it and at every stop light and sign it just stalled, then starts up again and goes then rev's up and down.
The seller said it needed a new carb, distributor, and intake.
I have all this but the dsitributor. What cold be wrong with it from people's experience. Keep in mind this has been sitting awhile and it needs new parts
Björn 01-14-2011 04:16 PM
congrats with the truck
Now the project can start
carnut122 01-14-2011 09:04 PM
Maybe a clogged fuel filter? Although it could also be distributor related. Points or electronic ignition?
jvmcc 01-15-2011 08:53 AM
I'm still slowly restoring my old '53. My bed alignment looked a lot like yours. Only it turned out that it was the cab that was leaning because of a bad mount, and not the bed frame.
michaelmilburn 01-15-2011 11:57 AM
Quote:
I shall soon find out, once I start that project!
mathew21 01-15-2011 12:32 PM
From what I can see it looks like a nice solid Truck. Congrats!
spurredon 01-15-2011 02:01 PM
Looks like you have a starting point better than many. I think the overall plan is a good thing but don't be surprised when you get part way thru it that you might change direction. Enjoy the journey!
