2006 F250 CC SB lariat 59k wrecked 6.0 4X4
***no pics yet will get pics after snow clears***
***TRUCK IS WRECKED NC SALVAGE TITLE*** 2006 CC SB Lariat 4x4, Bright red Tan leather, 6.0l tdsl, auto,will crank and lot drive. Basically cab back is good with workable dents, could replace two doors if did not want to work them. Front end is swayed over to right...front frame section is bent....but if you build wrecks you know that section of the superduty frame is replaceable at the factory joint. No Bags deployed, step bars are damaged, will need most front sheetmetal and headlights and header etc, some of the cooling is good some isn't....will need front frame section from factory joint forward. $8950 704-507-2453 |
