Archived Australia Buy/Sell/Trade Ads
G'day all,:-wink
We are looking for the following items for our 66 F350 project.:-roll * WANTED: Sunvisor brackets and visors. Any color any condition considered. Brackets only a definate yes if you have them !. 61-66 sunvisors brackets are different to all other models. *Strike the Visors and brackets off the list. Got some cheap ones off Feebay * WANTED: Windscreen wiper arms to suit RHD 61-66. Not sure if 67-72 are the same but 73-80 are different. LHD wiper arms are definately different !. * WANTED: V8 Bonnet badge. Needs to be OK condition or better. * WANTED: Indicator lever. Our F350 has the indicator lever on the left like for LHD vehicles. Our steering column is the Truck type I-Beam and early steering setup with 4 spoke steering wheel. Twin I-Beam columns are different and use a 2 or 3 spoke steering wheel so indicators off these are no good for our purposes,been down that road :-roll. 57-60 effy indicator lever may suit. Would also consider buying a complete column or column and steeringbox if the price was right. * WANTED: Front indicator lenses (not cracked) and good housings as well. These indicators are the type that fit onto the top front panel below the bonnet, not in the grille. * WANTED: 2 x F350 plastic insignia's to suit the Chrome housings mounted on the guards. Need to be at least good condition as we have already got "crappy to OK" units.:-wow Drop us a PM with what you've got and price. Some of this gear can be bought aftermarket from various US suppliers, but if we can source it locally then the "dough" stays in Australia. Here's hoping,:-X03 Cheers........Barry. PS. As per Australian Chapter rules, if the moderators so choose to delete this Want add because I am a member of less than 15 days duration of the Australian Chapter then so be it !. |
FOR SALE: 61-66 effy items
G'day all,
We've got a couple of items to suit 61-66 F100-F350 that are surplus to requirements. *FOR SALE: Fuel tank. Behind the seat type. Good condition with sender although I have never tested it. Sorry, no filler neck or rubber body grommet. $50.00. *FOR SALE: Indicator Stalk and assembly to suit LHD 65-66 F100-250 Twin I-Beam type 2-3 spoke steering wheel column. Working. $50.00 May suit earlier 61-64 F100 with the 3 spoke steering wheel column. Send a PM if you are interested or looking for other 61-66 effy stuff. Will have other "surplus items" to sell later once our project is on the road.:-X04 Cheers............Barry |
i need a style side bed for a 54 f100
03 F250 front bumper
In very good condition. Need to get rid of it, Make an offer
GTP38 turbo/pedestal
Out of my 03 F250. 160K on the clock. Rebuilt @ 140K No shaft play either way. Ceramic coated exhaust side. Wicked Wheel. No leaks on pedestal. I want $550 (gst included) will listen to any reasonable offer.
73-79 Supercab/crewcab
Hi all, I've got a cab off a 76 Supercab, 6 seats with 2 doors. I was wondering if anyone knew where I could buy a crewcab/dual-cab cabin, or perhaps swap for mine if it's in similar condition? Thanks!
91 Clutch Kit
I have a new single plate clutch, never fitted for a 91 F350 4WD 5.8 engine if anyone is interested.
I have a 89 wire harness with computer, If anyone is interested.
Also will have a repaired crash pad out of my 84 F250 (will be ready early Jan) I can paint it any colour if you get in early enough. |
hi everyone, i am looking for a 1974-1979 supercab truck or cab. my email is rhino8029@gmail.com. cheers.
P.S great site very helpful |
Lots of take off parts from a 2005 7.3 XLT
Stock H4 headlights, headlight surrounds, i indicators-side lights, perspex covers for stock headlight indicator set up (makes the front nice and flush), waste gate controller, 4 extended rear shackles with nuts and washers that will allow an EXTRA 3" rear block fitted, ONE 3" straight Riff Raff aramide IC boot (bought a pair but only one required for Mishimoto IC upgrade), pair of chrome bully pop up tie downs that fit in the bed stake holes, rear 'helper' leaf springs and their U bolts (stops excess rear sag when fulled laden - would be a good upgrade for a 'working truck') Also stock take offs all in good serviceable condition: IC and plenum boots, stock air box lid, stock AIH, stock turbo outlet with EBPV (can be used to make an exhaust brake), 4 bolt turbo EBPV pedestal - THIS IS IN NEED OF A SEALS KIT - however the EBPV can be stripped out and the hole blanked off with a bolt if you want to prepare one and keep your good stock one in working condition. PM me if any is interested in any of this. Want something for the aftermarket stuff (tie downs, helper springs, RR IC boot), stock items no offer refused ! Apparently the 3" straight boot is required if you upgrade to the Mishimoto IC. Anyone who's upgrading to a Mishimoto IC and needs one 3" straight boot, I have a RR aramid boot for cheap. |
Im in desperate need of a drop pitman arm to suit a 77 model f100 with a 6" lift.
6 stud F350 wheels, 74 F350 chassis, etc
G'day guys.
I got 6 x six stud F350 wheels for sale. These are not too bad, no major rust that I can see, but will need repaint. Also a 6 stud Dana 70 dually diff with 5.3s I think, big axles. 74 F350 chassis, includes front twin I beam and discs. Also a bunch of good 7.50 x 16 tyres. 6 Olympic steel flex and some others. Treads vary in depth from about 30% to 70%. Need to clean out. 2 x NP435 manual 4 speeds, both good, granny first gear, good for rock crawler. These things are good for between 430 and 450 ft/lbs of torque. 302 clevo, runs rough, needs rebuild, but has holley 2 barrel carb. Can ship wheels and tyres to freight depot on pallet, Melb and Syd. if interested. Last time I shipped a pallet to Melb. it cost $120, (about 16 mths ago) so it's probably a bit dearer now. All offers considered. Welcome to come see the stuff. PM me any questions. Cheers, Ron |
OEM pushrods 99-06 powerstroke
I have set of new OEM pushrods I dont need for 99-06 7.3ltr powerstroke
PM me if interested |
pair of SS pop up tie downs for F250 tub stake holes - as new - $30
Stock F250 2005 headlight and blinker assemblies including H4 bulbs - offers? New pair of 3" diameter RR Aramid IC boots (blue) to suit early 99 model - any offers? F250 2005 stock up-pipes and exhaust (turbo back) including muffler - could double as a header & high flow down pipe for a farm shed - any offers? |
REAR DIFF COVER
Rear Diff cover F250/350 Sterling.
$100 + Postage (Ignore the date on photos, haven't changed the date on camera). It's as good as new. .https://www.ford-trucks.com/forums/p...ctureid=102905 https://www.ford-trucks.com/forums/p...ctureid=102904 https://www.ford-trucks.com/forums/p...ctureid=102906https://www.ford-trucks.com/forums/p...ctureid=102903https://www.ford-trucks.com/forums/p...ctureid=101638 |
