1974 Black F100 Custom 2WD
For Sale 1974 F100 Custom 2wd pick-up. I have owned the truck since 1993. Would consider trades for 93-94 IDI Turbo or 94.5-97 Powerstrokes, 2 or 4 wheel drive.
DRIVETRAIN: 390 Bored .060 over with less than 10,000 miles on rebuild Ported/ Polished heads with 2.09/1.66 stainless valves, Performance 3 angle valve job Edelbrock Streetmaster Intake with Performer Carb Crane Solid Lifter camshaft Erson rocker arms High volume oil pump with windage tray Edelbrock aluminum high volume water pump Ram air set-up Ford T19 medium ratio manual transmission (5:1 1st gear) New clutch and flywheel Ford 9 inch rear with Detroit Locker 3.00 ratio (3.50 gear-set available) Dyomax headers 3" dual exhaust Lincoln Mark VIII electric fan Ford 130 amp 3G alternator SUSPENSION/BRAKES: 4 wheel disk brakes Front and rear aftermarket sway-bars Monroe Sensa-Trac shocks TIRES/WHEELS: Mid 90s Ford chrome wheels with BFG 31" TA/KO tires. 25% tread Wheel Vintiques 15X6 and 15X8 steel wheels with BFG radial TA tires. Brand New, 235 and 275 series front and rear. INTERIOR: Refinished bench seat Vinyl floor mat Aftermarket digital temp and volt gauge New headliner Pristine dash pad, no cracks! Factory cluster un-molested Delay wipers EXTERIOR: Recent black paint. Originally red with white top. NO RUST Excellent chrome and trim. Fabulous grille shell and inserts Hella H4 headlight conversion Heavy Duty Headlight relay Bed is unfinished, was pondering spray-in bedliner or plastic. No major dents or damage on bed floor. Have been using a 67-72 tailgate, also unfinished Have rear roll-pan if desired. Windshield excellent. Decent 3 foot quality bodywork, not car show quality, but easily turns heads. No dents and no rust. I am very proud of the truck and it has never let me down, but I just don't have the time to enjoy it like I used to and would hate to just have it sit around in the garage. It needs to be driven. After that long description I am sure I have left a few things out. I have YOUTUBE videos under user BULLITT406. The youtube videos, however, show when the truck still had the dual quad 428. The 390 I installed is just as healthy. https://www.ford-trucks.com/forums/p...ictureid=29565 YouTube - Ford 428 Exhaust Thanks, Josh |
very very clean truck. i have a few pics of these trucked save. just love it. one of the best f100's on the board. 5500 is a steal imo for how well this truck is and maintained!
truck sold?
Josh,
Has your truck been sold? If yes, then congrats and disregard the rest of this message. If no, is the shifter on the column or the floor? Does it have electronic ignition? Factory installed? Power steering? Factory installed? Disc brakes? Factory installed? Your time is appreciated. -Dave |
Sold March 2011 to a fellow FTE member (LongtravelHighboy)
Thanks Josh |
