codes 122 114
122
114 my code reader (3145) came up with these codes, but i have no idea where to get started. Anyone come up with these? 95 ford f250 5.8, |
Ford Fuel Injection » 3 Digit Self-test Codes 111-171
DTC 122 indicates the TPS voltage is too low with the throttle closed. DTC 114 indicates the ACT sensor was out of range during the test. That can be caused by excessive cold or hot weather when running the tests. Look here for expected TPS values: Ford Fuel Injection » Throttle Position Sensor (TPS) Look here for expected ACT values: Ford Fuel Injection » Air Charge Temperature (ACT) |
thanks ill go it that, and let the truck warm up and run the codes again
got code 22 and 122
any one know how to fix a truck that wont start with the code 22 and 122?
Originally Posted by Aaron89ford250
(Post 14423498)
Originally Posted by knobbytrav
(Post 20512609)
Did you figure out our? I have the same thing.
