Spark Plug Wire Crossfire?
I was just introduced to the Crossfire thing in another post I seen. I keep posting about a cold start issue but when it warms up it's fine. (I got the 5.0 V8 in a 92 F250 E4OD trans) It actually starts like it's missing a plug or something but it's tuned up completely with new wires, plugs, cap, rotor and coil. Now my question is this.... Even though I have BRAND NEW NAPA Spark Plug Wires could they still crossfire? I don't see any sparks when I open the hood in a pitch black area. Could the be crossfiring under the cap? If you wanna know all I've done and replaced you'll see it all on my previous post. But anyway I can guarantee My wires aren't routed right. I don't even think my separators exist haha! But if it is crossfire I don't know why it runs fine when warm. Thanks in advance (:
I have the same problem with my 89 F250 302/aod under load it misses, drove me nuts trying to figure it out, finaly I found this:
https://www.ford-trucks.com/user_gal...id=238366&.jpg Took care of the problem! |
Does anyone have the diagram for a '97 7.5l? I haven't seen it.
J |
this link may help if your firing order is different than one pictured above.
1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net Hope this helps everyone! |
Originally Posted by timbersteel
(Post 9733957)
1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net Hope this helps everyone! J |
Sorry J, didn't mean to sidetrack the Post. I posted the link for JV2290. I'll look around for the wiring diagram for the 78, 6.6
(Post 9734266)
J |
Unfortunately that wasn't my issue. I routed them correctly but It still runs bad. Thanks for the info anyway! I still learened something haha
I don't see any sparks when I open the hood in a pitch black area. |
Apparently the firing order in that sticker (Eddiec's) is only true for 5.0 engines built from 1994 on. The firing order for older engines, like mine, is 1-5-4-2-6-3-7-8.
I have the same problem with my 89 F250 302/aod under load it misses, drove me nuts trying to figure it out, finaly I found this: Your post above reference a picture, but the link is dead. What did you find? Steve |
Originally Posted by Maillemaker
(Post 19003091)
Old thread, but Eddie was active yesterday.
Your post above reference a picture, but the link is dead. What did you find? Steve courtesy of Steve83 |
Thanks. Is there something similar for a 1990 460 EFI engine?
Thanks, Steve |
The 7.5L and early 5L engine share the same firing order. The diagram I posted will work for your application.
Thanks. I am going to pick up some spark plug separators and see if it helps.
I've been struggling with an intermittent stumble/miss under load at top gear at 45 MPH. Steve |
