315/75R16 on stock wheel ?
Anyone have any 315's on stock wheels ? got pics ? trying to figure out if I need to buy wider rims......think they will fit ??
http://i674.photobucket.com/albums/v...er1/liftEX.jpg |
They do fit, I know, I have them...Mine is a 2wd, so I had to have a 6 inch lift for them to clear. But yours being a 4wd, you would need a 3-4 inch lift to clear them. Bottom line: they fit, but you need some lift...the largest you can clear without a lift and stock rims are 305/70/16 tires.
I just put rough country F350 2.5 " leveling springs under the front and 2" add a leaf on the rear...think It will be ok with 315's ? That is the pic now...you can compare to the profile pic
I have a 03 limited 4x4, with a 2" lift front and back, and just put a set of Mickey Thompson ATZ plus's 315/75/16 on factory limited rims and fit fine. The rims are 7" wide, but went on easy.I do only have about 1" of clearance from front bumper back to corner of tire and same from rear lower corner of wheel well to rear corner of tire when turning corners. I did have BF Goodrich's on but with the squareness of the corners of the tires the clearance I do have wouldn't be there that I have with the rounded corners of the Mickeys.
If you plan on any off roading-BEWARE. Only my .02.Nunomad |
Neil, I added 6 pic's to my 'various' album. ProComp all terrains. Stock rims. A little bailing wire on the inner fender and you're rollin'.
https://www.ford-trucks.com/forums/m...-a-little.html |
they will fit
i have an excursion 4x4. i added two leaf springs on the front (about 4" of lift) and three leafs in rear. i mounted 315/75/16 nitto all terrain on the factory wheels. i have never had tire rub while driving even off road. the tires do rub the leaf springs while fully turned. just get in habbit off not turning extreme!
Originally Posted by wpnaes
(Post 9646869)
1 Attachment(s)
The 315/75R-16 will physically fit on a 7" wide wheel but the "design rim width" for that tire size is an 8.5" wheel. Not many 8.5 inch wheel manufacturers out there so 8.0 is close enough. Not saying it won't work on a 7, just not the ideal situation.
(Post 9646869)
Ford Truck Enthusiasts Forums - wpnaes's Album: Various Ex Work - Picture |
315 Toyo Open Country AT 2's
http://i220.photobucket.com/albums/d...psmohznapy.jpg http://i220.photobucket.com/albums/d...pswwi0gt0p.jpg |
Originally Posted by njneer1
(Post 9645784)
