cruise control does not work
Recently the cruise control stopped working. Thinking that maybe the recall would repair this issue it has not. I have checked fuses several times and all are good. I tried getting info from Haynes manual and a DVD from a Ford service manual that was purchased on e-bay but has no dignosis lititure on this. Could you guys help me out?
Does yours have the update done? Mine worked fine then after they did it it stopped working.
Update? Do you mean recall yes had it done today. It stopped working before this. Thought it would fix the issue.
Can someone please help I got a 2 hr. drive Friday to Cinci Ohio would really like to have cruise. Just getting it back to the top.
Mine quit and it was the speedo sender on the rear axle.
$20.00 part. |
This speed sensor, would your speed MPH gauge not work if this sensor was bad? Because this gauge does work.
Auto or standard? If standard, check the clutch pedal switch.
Standard 6-speed. If this switch was bad the truck would not wont to start. I have a AE could this tell me anything?
Yes you could run a switch test with AE, but I'm willing to bet it's the CPP (clutch pedal position) switch. You can pick one up at the local parts store pretty reasonable. The worn springs won't keep the truck from starting.
Go ahead and pull it out and look inside there. Do you see one long spring on each side, or what appears to be multiple springs stacked on each other or broken like this https://www.ford-trucks.com/user_gal...182632.520.390 |
Ok guys I fell like where going around in circles here. The Cruise Control (Speed Control) does not work the truck starts fine the MPH gauge and RPM gauge works fine. Your telling me that these sensors are causing the problem or one of them.
i had the SAME problem...starts fine, ran fine...it was the clutch pedal switch. the part is like 80 plus dollars from ford, so i just made jumper wires and connected them to the connectors. there are 4 connections, if i remember, the first 2 get hooked together and the last 2 get hooked together.
NOTE: the truck will NOW START WITHOUT THE CLUTCH DEPESSED. make sure you depress the clutch or put the truck in neutral. i have also heard that the 3rd brake lite being burned out could cause a no cruise condition. no positive about this, but jim rat49f6 told me it happens. good luck |
Originally Posted by ronjon95
(Post 9569167)
Hope you find the problem! :-wink |
the rod that connects to my clutch pedal and runs through the firewall came off one time and now my cruise control wont work.
Ok thanks guys I understand now. It was just a little vage for me why it could be the switch make since know depress clutch pedal shuts off high idel and cruise. Duh on it right know to have a look see.
Originally Posted by robs01f250
(Post 9571291)
