LED light upgrade
Hi All,
Recently picked up a 2007 Navigator, Am going to be changing my front park lights and turn signals to white LED lights. Problem is the turn signal will do the "quick flash" (like when a turn signal bulb is blown) because of the lower voltage of the LED. I've fixed this on many other cars by replacing the factory turn signal flasher relay with an electronic flasher relay available from most parts stores. but don't know where it is located on Does anyone know where the factory relay for the turn signals/hazard lights is located. I went through my manual but couldn't find it. |
I can tell you in a couple of days when my factory manuals arrive. I just ordered factory service manuals and wiring diagrams delivered from Ebay for $33 total!!!!
From what I can glean from the manuals, the turn signal is all FET control from some control module. I would assume that this means its not the old school resistance type flasher. You could easily validate this by removing a turn signal lamp and seeing if the flash frequency changes.
^ removing the bulb does cause a "hyper flash" from what I've read I belive the relay is in the "smart Junction Box" in the passenger kick panel. Going to look for the relay this weekend.
Worst case if i can't find the relay I'll just add a load resistor for each bulb |
Originally Posted by Blacknav
(Post 9492783)
Hi All,
Does anyone know where the factory relay for the turn signals/hazard lights is located. Without Signal Mirror System 5C3Z13350AA With Signal Mirror System 2L1Z13350AA pictures More Information for MOTORCRAFT SF633 More Information for MOTORCRAFT SF624 looks like the flasher can be changed, i do not know the location |
