2001 - 2003 Ford Explorer Sport Driveshaft FRONT (A1 Cardone REMAN)
http://www2.1aauto.com/_include/gui/logo_large.gif
http://www.1aauto.com/img/ucart/imag...00002/main.JPG CHECK OUT OUR WEBSITE FOR CURRENT PRICING 2001 - 2003 Ford Explorer Sport Driveshaft FRONT (A1 Cardone REMAN) This FRONT Driveshaft is a newly remanufactured part that has been rebuilt to very strict quality control standards. It is just what you need to get your vehicle in good working order! Specifications: Replaces FRONT Driveshaft Rebuilt to strict quality control standards Replaces dealer part numbers: F77A4A376BB, XL2A 4A376 AA, F77A 4A376 BB, XL2A4A376AA No core charge Contruction type: U-Joint & CV Joint Not Double Cardan joint style which is a H bar with a u-joint on each end 3 Year Manufacturers Limited Warranty* Next Day Air Shipping available at extra cost Features & Benefits of this rebuilt driveshaft: 100% Dynamically Balanced. - Reduces vibration and increases joint life. Dynamic balance is better than static because the unit is balanced at the speeds it will see on the vehicle. 100% New Universal Joints Installed. - Ensures proper fit & function for optimal performance and durability All slip yokes are lubricated to O.E. specifications to prevent premature wear. High speed balancing at 3200 RPMs ensure vibration-free operation. All shafts are measured to guarantee proper fit. Drive shafts may need replacing for a variety of different reasons. On vehicles that do heavy work or endure other extreme use you can actually break a driveshaft or twist it. Many plow trucks will actually break the CV or Universal joints trying to push heavy wet snow. More often the CV or U-joints wear out causing noises and vibration while accelerating or slowing. *Backed by manufacturer's Limited 3 Year warranty. In the event this driveshaft should fail due to manufacturing defects during intended use, we will REPLACE the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty |
