Welcome to FTE. :)
I use the green coolant... |
Originally Posted by skaeke
(Post 14401163)
Today I bought my truck. A 1980 F-150 300ci. She sat idle for three years but started right up and drove the 20 miles to her new home. Tomorrow I start changing out all the fluids and giving her a good cleaning.
My first question on the forum (and it is super easy): What coolant should I use? The only thing I can find is in the owner's manual stating ESE-M97B18-C compliant. I've looked around and haven't found any matches as of yet. As for the coolant, just use a 50/50 mixture, green or universal will work fine. Extended life, if you know the system is in good enough shape to not be losing coolant in massive quantities..... These old trucks didn't require anything special, just the same old stuff that was used for years. |
I stay away from pink or orange.
Welcome! On the I6 you should check the tightness of the carb-to-manifold attaching bolts. They are know to loosen, but don't tight too much.
And, since it sat you can bet there is bad gas in the tank as well as gunk. I would replace the existing fuel filter with a new, clear one and put another one right ahead of the fuel pump. The rust in these tanks can really mess up a carb. |
Originally Posted by ArdWrknTrk
(Post 14401215)
Thanks for all the feedback! Extended life non-pink/orange coolant it is.
(Post 14401227)
(Post 14401227)
Good to have drained the old gas. But if there was water in the gas it may have created rust in the tank that will flake and get into the fuel. In my experience that stuff will plug up the accelerator pump orifaces pretty quickly, and cause flooding due to it getting stuck to the needle's tip. That's when I went to two filters and that seemed to solve the problem.
(Post 14401771)
(Post 14401835)
Makes sense for a nice cheap back up. I'll add it to the list for today.
I've also been researching a 5.0L OBDII swap for the Nissan. |
Yesterday I replaced my Passenger side power window motor.
Here's a link to the HOW-TO: https://www.ford-trucks.com/forums/1...ow-motors.html |
Today I checked all of my sparkplugs to see how the mixture was doing. I was surprised by what I saw.https://cimg0.ibsrv.net/gimg/www.for...44eb75e8e3.jpg
https://cimg1.ibsrv.net/gimg/www.for...bf3f25397c.jpg https://cimg2.ibsrv.net/gimg/www.for...f4e435e1ab.jpg https://cimg3.ibsrv.net/gimg/www.for...109bc4e3fa.jpg https://cimg4.ibsrv.net/gimg/www.for...cb06a507ff.jpg https://cimg5.ibsrv.net/gimg/www.for...9376186328.jpg https://cimg6.ibsrv.net/gimg/www.for...6ef4b5ff4e.jpg https://cimg7.ibsrv.net/gimg/www.for...a9303978a1.jpg https://cimg8.ibsrv.net/gimg/www.for...5990813ee3.jpg The second picture is actually number 3. I ran a compression test on all of the worst looking plug holes and they all came out to 155 PSI. Not sure why they are like that, last time I checked them all they were all a really light tan color. Engine doesn't burn a drop of oil, doesn't smoke a bit. Although it has been run in the driveway a lot lately. Runs smooth as can be. Have to keep an eye on it I guess. Valve seals were new last summer, or about 800 miles ago. |
This is what they looked like the last time they were all out at the same time, last July.
https://cimg9.ibsrv.net/gimg/www.for...ffbbada624.jpg https://cimg0.ibsrv.net/gimg/www.for...ae7c0540fe.jpg |
How many miles did you put on it in the last year Matthew?
(Post 14403007)
Matthew - You need to focus on the plugs, not the engine. But, I can see that those plugs are dark. So if the same plugs were light earlier then something is causing it to run rich. Power valve?
