Originally Posted by FordFETruck
(Post 12457607)
So we looked at the oil sample I took, looks like a lot of brass, VERY fine brass. What the hell is brass in a 351W? it's too bright and shiny to be copper or anything like that.
I'm gonna take another oil sample tomorrow. |
(Post 12457649)
What's the bottom distributor bearing made of?
Make sure to check the gear, as if it is going it'll put side-thrust on the bearing and take it out.
(Post 12457669)
Just thought I would share what I have done to the truck so far for the up comming winter season, and get to know some FTE members. Yesterday I changed the oil with 6 quarts of Napa brand 10w-40, K&N oil filter, new 18" Napa winter wiper blades, replaced the leaking LR wheelcylinder, and today gave the truck a good undercoat of trans.oil and desiel fuel.
Earlier this year I changed the gear oil in the Warn 4 speed, flushed the radiator, rotated the tires. I also replaced the front shocks and the LF upper and lower balljoints. So far the Ford runs great! |
Today I pulled the distributor, everything was fine on it. I took another oil sample and this time pulled the drain plug out, looked like a hair ball on the magnet!. Very fine shavings almost like a sludge. I installed a new double roller timing chain 30-40 miles ago, could it be from the new chain wearing in?
Originally Posted by 82' F-100 Man
(Post 12460126)
(Post 12460398)
(Post 12461318)
Sounds like you have it in good shape. And, I thought I was familiar with the transmissions Ford used but I haven't heard of a Warn. Tell me more.
I wouldn't have thought a timing chain would give off that much stuff, but if it is stuck to the magnet it isn't main, rod, or cam bearings - unless you've worn clear through the bearing material and are into the backing. And, that's highly unlikely. You checked the gear on the dizzy and it is fine, so that would seem to leave the timing chain and the lifters and cam lobes. Did you also install a new cam and/or lifters? What about the oil pump - it is a new high-volume unit? |
I noticed somebody coated their truck with diesel and tranny fluid. I coated my truck with engine oil I thinned out. I figured it would get into the cracks better. Anybody tried this before? Also my heat only works on the highest setting otherwise no air blows . . . any advice on that would be appreciated
Originally Posted by regret
(Post 12461847)
The theory on thinning it out was that it would flow better into the spots **** usually rusts. Anyway the fan wont blow until it's on the highest setting. It works perfectly in that setting, but in the others it doesn't blow at all. Even on cold or different settings.
(Post 12461855)
I drove my truck lookin for an open library with no success.http://www.rxor.info/01.jpghttp://www.rxor.info/22.jpghttp://www.rxor.info/8.jpghttp://www.rxor.info/03.jpg
(Post 12461847)
I don't know for sure where it is on the Non-A/C trucks.. Anyway, when you unplug the plug and remove it, it will have little coil type springs going across the contact legs....They usually burn up and break....Just replace the unit. They aren't too expensive..and REAL EASY to change...Hope this helps you....Trav.:-wink |
About to go put some gas in the truck and run some errands.
