good source for lower door seals?
My truck has been missing the lower door seals since I bought it, and likely much longer given the rust I just fixed along the door bottoms. x(
Does anyone know a good source to get the seals from? Truck is a e99 7.3 sc sb if that makes a difference. The dealer is quoting me $40 per door, so $160 for all 4. Wondering if there is somewhere cheaper to get them from? |
Originally Posted by akorcovelos
(Post 9454101)
Does anyone know a good source to get the seals from? Truck is a e99 7.3 sc sb if that makes a difference. The dealer is quoting me $40 per door, so $160 for all 4. Wondering if there is somewhere cheaper to get them from? Try Parts Guy Ed, site sponsor here www.partsguyed.com |
I don't see a listing for the lower weather stripping, just the uppers...
F81Z2520758AA RH and LH - bottom of front door, New design - L shaped - must be mounted on door so when door is closed the L shape closes and makes a V shape, to make a proper seal, also push pins must be installed all the way or weatherstrip will be loose., 1999/2004 ; Ford 250 Series
great! Couldn't find those browsing by make/model. I only see the front doors listed, do you carry the seals for the super cab half doors? Do you carry the push pins as well?
check your local wrecking/salvage yard. i guarantee they have super duty's, the door seals may not be new but they will be inexpensive, LMC truck might have them too.
PartsGuyEd for sho.
Don't know if I will re-install my new ones though. Seems all they are good for is collecting nasty and rotting out your lower doors. (Ask me how I know! :-lamesign) Do they actually keep anything out or what? I haven't noticed anything coming in so far in just rain. |
Originally Posted by Boss_hoss
(Post 9455313)
(Post 9455343)
I checked the local yard because I need new mirrors, not one super duty...
I'm pretty sure they keep splash up out of the bottom door area. the rotting usually comes from the inside out, when the door drains get clogged and runoff from the window/upper door hangs up in side the bottom of the door.
(Post 9455313)
these things only list for $19 bucks.:rolleyes: |
(Post 9454448)
1C3Z28253A24A BODY SIDE DOOR LOWER AND 253A25, WEATHERSTRIP: [SUPERCAB NEW DESIGN L SHAPES - MUST BE MOUNTED ON THE DOOR SO WHEN DOOR IS CLOSED THE L SHAPE CLOSES AND MAKES A V SHAPE, TO MAKE A PROPER SEAL, ALSO PUSH PINS MUST BE INSTALLED ALL THE WAY OR WEATHERSTRIP WILL BE LOOSE. CLIPS INC |
Hello all. I need the lower strips the OP is referring to, but I also need the same strips for my rear doors as well. I can't seem to find the part# for my rear doors. I have the full 4-door F-350. Thank you.
I need to replace these on my rear doors as well as one front door. They do keep mud out from between the door and the area right under the inner seal. I don't have an actual part number, but if you look at Parts Guy Ed's website (Horizon Ford, just click his links above or do a Google search for 'partsguyed') you'll find them under:
Collision Catalog - (YEAR) - Ford - F-350 SUPER DUTY body hardware, rear door, door & components, lower wstrip CREW CAB Left (or right obviously) |
It says CREW CAB, which I thought was the half-door trucks. After that it says SUPER CAB which I was thinking my full 4-door truck is, but it doesn't list a strip for the SUPER CAB.
