map sensor
1992 f150 4x4 5.8 efi 5.8 e40d transmission
can someone please tell me how to tell if the map sensor is bad? my truck would not idle, i changed the tps,ect, iac. I have checked for vacuum leaks and put in new sparkplugs and wires. if i pull the vacuum line off the map sensor, the engine smooths out and idles fine, but shifts a little rough |
You could have saved yourself some $$ by first checking for codes: Ford Fuel Injection How To Run a Self-Test
Use this as a reference for checking your MAP sensor: Ford Fuel Injection Manifold Absolute Pressure Sensor (MAP) |
You can also use a tachometer to test it.
If you do not have or cannot afford to buy a hand vacuum pump or tachometer, you may be able to rent one in a major auto parts or equipment rental store. 1. Set the tachometer to the four-cylinder scale (regardless of how many cylinders the engine has). 2. Connect one tachometer lead to the middle terminal on the MAP sensor and the other tachometer test lead to ground. 3. Connect the two jumper cables the same as before, attaching each end terminal on the sensor to its respective wire in the wiring connector. 4. If you want to measure engine vacuum so you can correlate it to a specific frequency reading, connect a vacuum gauge to a source of manifold vacuum on the engine, or tee the gauge into the MAP sensor hose. 5. Turn the ignition ON and note the initial reading. The reading on the tachometer should be about 454 to 464 at sea level, which corresponds to a frequency output of 152 to 155 Hz. 6. Start the engine and check the reading again. If the MAP sensor is functioning properly, the reading should drop to about 290 to 330 on the tachometer, which corresponds to a frequency output of about 93 to 98 Hz. No change would indicate a defective sensor or leaky or plugged vacuum hose. Here is the hook up: http://i54.photobucket.com/albums/g9...TestHookup.gif / |
I pulled the codes via ford code reader and here it is
koeo-111 koer-8,412,116,411,538,536,632 **I failed to mention that I got the iac at a wrecking yard,cause I didnt want to spend that much until i knew for sure, but it didnt make a difference,(maybe another bad iac??) |
