Interesting how warranty claims are spiking within the last 3 years.
Automotive Warranties, 10 September 2009 |
No problem rises to a "major problem" until it happens to you.
The term insignificant is in the eye of the victim, I think. Hopefully we can all learn things we can do to lessen our chances of being one of the "insignificant" numbers. At the very least a discussion of preventitive steps we can all follow is helpful and worthwhile. And we are sure learning about each other here....aren't we?? Jim |
Do the newer fords (6.7) have the fuel mixer in the fuel tank? If so I would remove it and do the strait tube mod to get any air bubbles out of the fuel system. Like I mentioned pressurizing the fuel at 30,000psi will make ANY air bubble detonate in the fuel pump causing failure.
Like I see others have mentioned and done I would also have a very good aftermarket or big truck fuel filter and water separator system on the frame somewhere. Is it possible to add something like 2 cycle oil in the fuel with the 6.7 or does it not take to kindly to stuff like that? Would help to lube the pump. I run it in my 7.3 to help lube the injectors. |
Originally Posted by farmerdave
(Post 11556217)
True! I still think we need to lobby for a higher quality fuel. At least Canada's specs for down here in the US.
Side note: I have a friend whose brother in law used to buy fuel, refine out the excess lubricants, resell the fuel. Then sell the lubricants. Sounds very shady to me. For my Northern Friends -- what is the average price of diesel? And how much are you taxed per gallon? I am going to assume that the regulations will mean more $ at the pump. We'll see. I am wondering (convinced) that more regulations (scar rating, etc) will have a bearing on the price --- hope I am wrong. I am doing business with the 3rd largest refinery in the U.S. and can assure you that there is no H2O in the fuel when it leaves. Same applies to every refinery that I have been involved with for 25 years. I suspect that the distribution system (condensation, poor filters, unclean transporter, etc) may need to be looked at. |
After reading this I am thinking a AirDog with a DAHL 150 on the return side of the AD going back into the filler tube on the truck. And continue to add Ferd's additive. O and keep it routed though the factory water separator for my WIF notice if for some reason I fill up my truck with H2O. Anyone see a problem with this set up? May be a little overkill but $10,000 fix has me scared.
Originally Posted by Snowseeker
(Post 11559463)
Well Ford Has treated me very good as a customer. Thats why I have a new Ford in my driveway. They are Quality in my mind wouldnt buy anything else for a truck. These forums are one sided you dont what these customers do with the truck, but Ford does they have a black box that knows all.:-X19
I'm know where your headed Adobe. And I agree with your logic.
Originally Posted by FONRDAY
(Post 11562697)
Your comments lead me to believe you are new enough to this scene to not have followed the story that lead to this and other threads like it. Impeccable maintenance always performed at a dealer did nothing to ensure the quality of service part of the story. If you had been following along, you would also know that the black box does not know all...but after my HPFP failure, it does know more. Prior to my failure, the computer did not store WIF indication information. If you had a WIF indication, and I never did, and the light was reset...the data was gone...Ford actually told me to prove I never had a WIF light knowing it was impossible to prove the point in either direction.:-X19:-X19:-X19 Someone might need a little more research.... Now, how about a return to the original points of the thread... Regards |
I haven't done the exact math, but I'd guess its $5-5.50/gal on average in Canada. $1.10-1.40/L or so depending on where you are.
You know what really pisses me off, our fleet has a 2012 and yea so far it's doing great, so I called to talk to a service manager to ask him about these hpfp issues. His response was, I've never heard of that! It must of been due to the owner not taking care of his maintance like he should. I said well, what do I need to do prevent this from happening to me? He says, read the owners manual and do as it says, and use oem filters and oils, especially fuel filters! He sai the aftermarket filters didn't have the protective lining around the filter to keep the water from passing through it. The part that upset me was he defended ford in saying there is nothing wrong with the truck or pump, but it was the owners fault! Seems like if it happened to one truck a bulliten would be posted at the dealers to watch for this of share the word of how to avoid this catastrophe from happening.
Originally Posted by bulla
(Post 11564381)
(Post 11564381)
Regards |
I was able to hold out and not read this thread until yesterday. Wow, lots of stuff.
Unfortunately, it is my opinion that the saying "chicken or the egg". Comes to mind. Here is my thought: 1. HPFP failure has nothing to do with water, dirty fuel, operator error, fuel scar rating. 2. Nothing wrong with working at it though. What the core of the problem is? Certain service advisors don't know how to deal with their jobs, get in warranty trouble with ford, and then make bad decisions trying to cover their behinds. Bosch or anyone else can't make 300,000 precision devices without a few of them failing. It just happens. Now, if someone does get a ton of water in their fuel, draining it from the separator repeatedly, then driving on and has a failure, that is different. So the talk of protection is cool if you think you need it. But, 99% of the energy in this topic is mis-directed. Warranty spike? Yes, look at the complexity of the engines. Goes hand in hand. Same thing with race cars. The more you push the tolerances, the more maintenance and repair is required. Just my opinion, I'm not important enough for y'all to go nuts if you don't agree. Have fun with the projects! |
Here is my thought: 1. HPFP failure has nothing to do with water, dirty fuel, operator error, fuel scar rating. If poor scar ratings are not a contributing factor to the pump failures, why is there a significant decrease in the HPFP failures in Canada where the fuel is mandated to be 460 Scar? I agree that a certain number of a high volume complex assembly like the Bosch CP4 series HPFP will fail. If my pump, which did just fail due to poor fuel lubricity, had been replaced under warranty as it should have been, we would likely not be having this discussion. GM has decided there is enough potential for poor fuel lubricity related HPFP failures to warrant replacing these pumps under warranty coverage. With a problem just as large as Ford's, GM has avoided the bad publicity. Regards |
