Originally Posted by Zip
(Post 11119145)
They always seem to know when you have a little extra cash.
which before all that started i had to fight with the inspectors to get it to pass... everytime i took it in they "found" something new... fogs didnt go out when the highs came on, seat belts that hadnt worked in 10 years were suddenly "not passable" then they said my tires were rotted too bad that i needed new ones.... took me $800 just to pass inspection this year... i swear my truck has the perfect nickname "money pit",,, ohh and last week the window bearing that actually pushes and pulls on the window to make it go up and down broke in 3 pieces so im waiting on the parts to get here to fix that... by time i get done fixing this truck itll be pretty brand new lol.. |
Ya no kidding
Originally Posted by Steve GG
(Post 11119154)
I would rather not be debt full.
I think every country is debt full.
Sounds like a lot of aggravation..
Originally Posted by Sparky83
(Post 11119158)
sure does... since september ive been trying to get rid of a bad vibration its been having.. which think i have it almost gone now too... started out with bad tie rods, which since i was replacing those i went ahead and did the ball joints.. but didnt solve the problem... changed the trans mount since it was split half way through... got it a little better but still bad... then did the u-joints, no change.. recently i changed the bushins in the frame and springs since the springs were literally twisting where the bushings were at... which i replaced them with polys but in the process of doing that i found that my rear shocks were shot... and when i checked the front ones they were just as shot... but least now its running smoother...but can still feel it there a little... still want to do the front ones and then have the tires checked again....
which before all that started i had to fight with the inspectors to get it to pass... everytime i took it in they "found" something new... fogs didnt go out when the highs came on, seat belts that hadnt worked in 10 years were suddenly "not passable" then they said my tires were rotted too bad that i needed new ones.... took me $800 just to pass inspection this year... i swear my truck has the perfect nickname "money pit",,, ohh and last week the window bearing that actually pushes and pulls on the window to make it go up and down broke in 3 pieces so im waiting on the parts to get here to fix that... by time i get done fixing this truck itll be pretty brand new lol.. My Bronco is going to need an inspection before I can drive it. It was pulled off the road before it got parked. |
(Post 11119167)
(Post 11119170)
On a positive note it should be pretty solid once you are done.
I guess you will find that point or get to the point where it seems to nickel and dime you to death.
(Post 11119177)
That would probably make things a whole bunch simpler. The fact that that's the plan if it happens means it probably wont happen. That engine will last forever.
That sounds like a lot of work. And that won't be thrifty on gas..
(Post 11119184)
(Post 11119185)
Talk about, I don't want to see a hill when I am cruising..
(Post 11119192)
