(Post 14403132)
Matthew - You need to focus on the plugs, not the engine. But, I can see that those plugs are dark. So if the same plugs were light earlier then something is causing it to run rich. Power valve?
I wouldn't worry too much about it.
Lots of idling in the driveway, lots of cold starts will cause that. IME, no amount of driving will burn soot off plugs once it shows up. Carbon needs at least 1.300 degrees to ignite. |
The good thing about it is all of the electrodes were DRY. I've had them all fouled as can be before from working on it so much, and 100 miles later all white, weird.
The electrodes were white, or the insulators???
Originally Posted by ArdWrknTrk
(Post 14403168)
Just drive it and enjoy it.
If it starts to cause running issues, plugs are only a buck and a quarter. |
(Post 14403206)
(Post 14403157)
So if you get it hot enough to burn carbon it may do some catastrophic engine damage.:-jammin How hot do gassers run when they are being labored? |
Where? The cooling system? The top of the pistons? The exhaust?
Today (Day 2 of ownership). I took a few hours to start cleaning the engine bay, drain the oil, replace the ancient wipers, clean out the interior, etc.
(Post 14403206)
IDK?
Seems I always get 8 Autolite 25 plugs for around $10. I sprayed some epoxy on that old hood and fenders I have. The rot on my truck is pretty bad. Time and money. The two never seem to be in the same place. |
I use Motorcraft plugs in all my Fords, Champions in the Chryslers.
Originally Posted by 85lebaront2
(Post 14404338)
I use Motorcraft plugs in all my Fords.
NGK only in everything here. Everything runs great with them. The old dodge van runs excellent with NGK. Hasn't had a champion in it since 1985.
