Originally Posted by bruno2
(Post 14388431)
Bill, I don't know exactly what is wrong with it yet. It did this all of the sudden and there were no symptoms leading up to it. I drove to the shop Tuesday morning without issue, but when I got off work and changed back to the Dodge it went queer on the ride home.
It didn't want to engage into gear. When it did it was like it was in and out of neutral and wouldn't shift up. I tried manually shifting and nothing. I tried going through tow/haul mode and OD off to see if that made a difference, but nothing.I can make it shift if I go wide open throttle. The fluid is full, but it looks awful. It's brown , but what was on the dipstick doesn't look terrible. |
Originally Posted by Rogue_Wulff
(Post 14389769)
Fluid being brown, not good. It is *possible* that fresh fluid/filter may bring it back to life, but the real question is, for how long......
Originally Posted by 5280
(Post 14389714)
I scored a ZF5 for my truck today!
Congratulations. :-drink |
(Post 14389714)
Originally Posted by ArdWrknTrk
(Post 14389917)
Lucky you!
(Post 14390011)
Congrat's! Does it need rebuilt? And what fluid are you going to run?
I have not explored fluid options, open for suggestions and experience here. |
I'm using Royal Purple MT lube, but what I've read says a good synthetic lube is recommended. The synchros are a weak spot on the ZF and the synthetic is good for them.
The tag on my filler says "Use Only ATF Ford Type H"
I'm using RP Syncromax. ZF's recommendations are all over the place depending on climate and duty. 75 weight gear oil, synthetic ATF and some types of regular motor oil. Most of these are (were) only available in europe. |
Gary, Jim, Thanks for the feedback on the trans fluid. I am a big fan of synthetic fluids, I will definitely go that way.
Cold as hell in the winter where I live, I'm hoping that once I get all of the bugs worked out of this truck my wife will use it for her winter driver instead of our very unreliable Land Rover. I will find a fluid that suits winter needs or switch out by season. |
(Post 14390203)
(Post 14390252)
Cold as hell in the winter where I live, I'm hoping that once I get all of the bugs worked out of this truck my wife will use it for her winter driver instead of our very unreliable Land Rover. I will find a fluid that suits winter needs or switch out by season. Nice find on the trans, assuming it is in as good condition as claimed. |
RW,
What do you think of people overfilling (through the shifter) to keep the ZF quiet? I've heard a lot of this, but have not tried it. ETA: when I bought it from Amazon it was under $15 a quart. Still pricey, but not $20+ at the LAP. |
UPS says my intake should be here tomorrow, and luckily for me, I have off all day tomorrow so I can be home when it arrives!
Gonna make a junkyard run for Chris in the morning, and then pick up some other rebuild goodies. Also started my new job today. Well, new store at least. Same job and company. lol. Cut my travel time and mileage in half. So that means less gas money out of my pocket, and more towards my savings. :) |
(Post 14390305)
RW,
What do you think of people overfilling (through the shifter) to keep the ZF quiet? I've heard a lot of this, but have not tried it. We just installed a reman NV5600 6 speed, and the rebuilder called for ~1.5-2qts more oil than NV/Dodge specified. |
Originally Posted by Fordzilla80
(Post 14390311)
Gonna make a junkyard run for Chris in the morning, and then pick up some other rebuild goodies. Also started my new job today. Well, new store at least. Same job and company. lol. Cut my travel time and mileage in half. So that means less gas money out of my pocket, and more towards my savings. :) In any event, if you could keep your eyes open I'd appreciate it. |
(Post 14390377)
If you don't mind, I'm looking for a 3-sheave crank pulley that has the front 2 sheaves of exactly the same size. Ray1986F150's EFI'd 302 appeared to have exactly the right pulley but I am not finding any in salvages here. And there is quite some confusion as to whether Ray's is actually a 3-sheave pulley or a balancer with an integral sheave and a 2-sheave pulley added on.
