Ford N700 door tag decode
https://cimg1.ibsrv.net/gimg/www.for...8638f700cd.jpg
I recently recovered my uncle's stake truck from a barn that was about to fall down on his farm. I remember this truck from my childhood, but I don't know anything about it. I would greatly appreciate any info you are able to provide. I'm sure I will be back requesting parts help when I dig into this project in the spring. Thanks much! Dave |
1970 f600
Originally Posted by searay60
(Post 18918433)
new to me, any help would be appreciated
https://cimg0.ibsrv.net/gimg/www.for...c6947d013e.jpg L = 534 4V U = Louisville KY Assembly Plant. F55300 = 1969. 146" Wheelbase. J = Rangoon Red. F000 = F1000 (gas), 32000 lbs. GVWR D81: D = Black all Vinyl / 81 = 81B Custom Cab. U = Dana/Spicer model 6852-G 5 Speed Direct. DPE: DP = Eaton model 19221 Two Speed Rear Axle / 6.17/8.40 / 23,000 lbs. Rear Axle Capacity. E = Ford-Rockwell/Timken 9,000 lbs. Capacity Front Axle w/o Heavy Duty Front Brakes. 32,000 lbs. Gross Vehicle Weight Rating. 235 net HP @ 3,000 RPM 87 = Purchased by a Body Company. |
Originally Posted by BroncoDave
(Post 18924622)
I recently recovered my uncle's stake truck from a barn that was about to fall down on his farm. I remember this truck from my childhood, but I don't know anything about it. I would greatly appreciate any info you are able to provide. I'm sure I will be back requesting parts help when I dig into this project in the spring. E = 361 2V FT engine. U = Louisville KY Assembly Plant. E15065 = 1969. 199" Wheelbase. J = Rangoon Red. N700 (gas), 22,000 lbs. GVWR 4C81: 4C = Black all Vinyl / 81 = 81A Standard Cab. M = Clark model 285V 5 Speed Direct. 54D: 54 = Rockwell model H170 Single Speed Rear Axle / 6.83-1 / 17,500 lbs. Rear Axle Capacity. D = Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle. 22,000 lbs. Gross Vehicle Weight Rating. 182 net HP @ 3,800 RPM 33 = Detroit MI Ford District Sales Office, where the original selling dealer ordered the truck from. |
1971 F600
Originally Posted by dmtanderson
(Post 18924999)
C = 330 2V Medium Duty FT engine. V = Kentucky Truck Assembly Plant. M20001 = 1971 (1971 F100/750 serial number range: J70001-M30000). 156" Wheelbase. G = Chrome Yellow. F602 = F600 2WD (gas), 20000 lbs. GVWR 4 8: 4 = Black Vinyl / 8 = 81A Standard Cab. A = New Process 435 4 Speed Manual Transmission. 64 = Rockwell model F106 Single Speed Rear Axle / 6.80-1 / 15,000 lbs. Rear Axle Capacity. 20,000 lbs. Gross Vehicle Weight Rating. 164 net HP @ 3,800 RPM 76 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from. |
Thank you, sir!
71 f600 pto Info
I have a 71 f600 that was converted to a hydraulic dump truck from a 30ft u-haul. I would truly appreciate any info regarding the options for the pto pump that was installed. I currently cannot raise the bed to do any cleaning or to find the stamp or plate etc. In the process of rebuilding the carb and locating a fuel pump. Any info on the pto or even the best way to go about finding it on my own would really help me.
Originally Posted by Joshua Cline
(Post 18928418)
I read your posts in the New Member Introduction Forum, there were two different 330 engines, post the VIN to determine which one your truck has. |
https://cimg4.ibsrv.net/gimg/www.for...8017cb06ea.jpg
Here is the VIN. Also, I am going to do a very thorough cleaning of the entire undercarriage once I am able to raise the bed. I will post all of the information that I discover once its clean. |
(Post 18928602)
Here is the VIN. Also, I am going to do a very thorough cleaning of the entire undercarriage once I am able to raise the bed. I will post all of the information that I discover once its clean. D = 330 2V Heavy Duty FT engine. E = Mahwah NJ Assembly Plant. L80178 = 1971. Original carburetor: Holley 2V |
77 F600
I would love to have any info you have for vin# F60DVY60119.
Also,I am in need for Wheel studs and lug nuts for the left front wheel, any chance any are available? |
Originally Posted by Brshctr
(Post 18931328)
I would love to have any info you have for VIN F60DVY60119.
Also, I am in need for Wheel studs and lug nuts for the left front wheel, any chance any are available? Probably from NAPA D = 330 2V Heavy Duty FT engine. V = Kentucky Truck Assembly Plant. Y60119 = 1977. VIN doesn't tell you much once it's decoded. Warranty Plate riveted to the left door face below the latch, post all the info stamped on it. Studs/nuts: I need the AXLE code stamped on the 2nd line-far right on the Warranty Plate, also need to know the size of the wheel, how many studs/nuts it has (usually either 5 or 6). |
(Post 18926730)
F00 = F1000 (gas).
L = 534 4V U = Louisville KY Assembly Plant. F55300 = 1969. 146" Wheelbase. J = Rangoon Red. F000 = F1000 (gas), 32000 lbs. GVWR D81: D = Black all Vinyl / 81 = 81B Custom Cab. U = Dana/Spicer model 6852-G 5 Speed Direct. DPE: DP = Eaton model 19221 Two Speed Rear Axle / 6.17/8.40 / 23,000 lbs. Rear Axle Capacity. E = Ford-Rockwell/Timken 9,000 lbs. Capacity Front Axle w/o Heavy Duty Front Brakes. 32,000 lbs. Gross Vehicle Weight Rating. 235 net HP @ 3,000 RPM 87 = Purchased by a Body Company. Thank for the help, I’m sure I’ll be needing more as this project moves forward. im interested in shop manuals, parts lists for this truck if there is such a thing. I will be doing a body off restoration |
(Post 18931404)
im interested in shop manuals, parts lists for this truck if there is such a thing. I will be doing a body off restoration Try faxonautolit.com for a shop manual, owners manual, sales brochure and etc. paper ephemera that silverfish love to feast on. |
(Post 18931392)
F60 = F600 2WD
D = 330 2V Heavy Duty FT engine. V = Kentucky Truck Assembly Plant. Y60119 = 1977. VIN doesn't tell you much once it's decoded. Warranty Plate riveted to the left door face below the latch, post all the info stamped on it. Studs/nuts: I need the AXLE code stamped on the 2nd line-far right on the Warranty Plate, also need to know the size of the wheel, how many studs/nuts it has (usually either 5 or 6). The door had been replaced, thankfully he swaped the plate over to the replacement door, thank you so much for this info. |
