I do not recall seeing anything there, but will check again tonight, thanks.
Looked again tonight, all around the carrier and I am not seeing any other numbers.......
Driver side axle tube inboard of spring? Can you see the Eaton PDF I linked to?
Originally Posted by fyn409
(Post 18855894)
Any thoughts on this rear? I need to replace the front seal and I would like to identify the seal number I need before tearing into it.
Thanks, Ryan https://www.differentials.com/techni...dentification/ maybe they can help you |
Originally Posted by 72rustwarrior
(Post 18858654)
I have used this site to help identify diffs:
Originally Posted by 85e150
(Post 18858652)
Serving suggestion: Pull the yoke and front of the diff to the point you can get to the seal. Look for numbers and search by those.
Some risk there, but otherwise you have a road oiler. |
How old is this truck?
I'll try my luck, I'm an old econoline guy, but NumberDummy knows all... If you go by 1972 numbers Wheel Base 189" , f-600 series truck,390-2v-8cyl engine,made at Kentucky plant, paint color Medium Bright Aqua & Lt Blue, Chassy cab ,Transmission newprocess 435-4speed,of course 23,000GVW,the DSO is the district special order code, I can't find and axle code for "E34" that's the best I can do with it |
(Post 18858708)
Some risk there, but otherwise you have a road oiler. Thanks, Ryan |
Originally Posted by Azlin
(Post 18856299)
I'm new to this forum, but after reading through the messages it appears to me that NumberDummy has most if not all the answers, so I'm wondering if you would be so kind as to tell me what you can about this truck from decoding the VIN??? We are trying to find parts for it but everything we order is not right, leading us to believe the information we have is incorrect. Any help would be appreciated.
https://cimg2.ibsrv.net/gimg/www.for...586520ead6.jpg H = 370 2V or 4V V = Kentucky Truck Assembly Plant. GA1132 = 1980. 3B = Midnight Blue Metallic. 584498: 58 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from. 4498 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." 189" Wheelbase. F612 = F600 2WD (gas), 23,100 lbs. Gross Vehicle Weight Rating. AB8: AB = Blue all Vinyl - Full Width Seat / 8 =Conventional Cab. A = New Process 435 4 Speed Manual Transmission. E34: E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,600 lbs. Rear Axle Capacity. 4 = Ford 7,000 lbs. or 12,000 lbs. Capacity Front Axle without Power Steering. |
Originally Posted by Mikeiby
(Post 18856563)
Hi, I have a 82 F 600 with a 4 speed transmission that has a piece of speedometer cable in the speedometer gear assembly in the transmission. How do I remove the gear assembly from the transmission so I can get the piece of cable out?
https://www.drivetrain.com/parts-cat...n-illustration |
(Post 18846177)
I have a 82 F 600 that has a piece of speedometer cable broken off in the speedometer gear in the transmission. How do I remove the speedometer gear assembly from the transmission so I can get the piece of cable out?
The DRIVEN gear attaches to the cable with a clip. |
Numbers Dummy.
Any chance you'd have part numbers for the metal coolant pipes on a 63 SD engine in a C850. Mainly the one that goes between the coolant reservoir and the engine, as well as the one between the engine and upper radiator. The ones for my reservoir is rough and the one for the rad has some weird fitting that looks to have been brazed in by a crosseyed howler monkey. Sadly both are among the few things from my parts truck. I know I could just use a long flexible hose but I figured I'd see if someone is sitting on an old one anywhere first. I'm going through the cooling system and so far everything looks good but those two. |
Originally Posted by Hillbillysuv
(Post 18861536)
NumberDummy.
Any chance you'd have part numbers for the metal coolant pipes on a 63 SD engine in a C850. Mainly the one that goes between the coolant reservoir and the engine, as well as the one between the engine and upper radiator. The ones for my reservoir is rough and the one for the rad has some weird fitting that looks to have been brazed in by a crosseyed howler monkey. Sadly both are among the few things from my parts truck. I know I could just use a long flexible hose but I figured I'd see if someone is sitting on an old one anywhere first. I'm going through the cooling system and so far everything looks good but those two. https://cimg1.ibsrv.net/gimg/www.for...7ea8c90725.jpg |
Thank you Sir!
8002 8290 |
