Texas Dept of Agriculture governs the fuel dispenser METER, not fuel quality.
True! I still think we need to lobby for a higher quality fuel. At least Canada's specs for down here in the US.
Side note: I have a friend whose brother in law used to buy fuel, refine out the excess lubricants, resell the fuel. Then sell the lubricants. Sounds very shady to me. |
Sorry if you guys thought i'd have pictures of my filter alarm, got sidetracked last night.
I always have projects like this on the go. |
Is the 6.7 powerstroke one of a kind? As in compared to the 6.7 Cummings, 6.6 duramax, or even the 6.4 powerstroke. They all burn the same fuel. What prevents them from failing? Seems like no matter how you add it up, there will always be a little water in your tank. It's called condensation.lol any time a rise and fall in temps occur, moisture is drawn. Even just the humidity over time will accumulate. I have no dealings with the 6.7 so there is alot i dont understand, but the one thing that sticks out to me is the need for additive or some sort of lubrication.
buy quality fuel and ad pm22 and drive it like u stole u will be fine
:-wink |
Till your the one going thru this hpfp failure!
It's not the HPFP failure thats devastating and making a big issue, it's the aftermath.
All trucks until now have had fuel system failures, this is unique in that it takes out the entire system and causes major damage, and also ford is being a grinch about warranty. |
Originally Posted by bulla
(Post 11556714)
Originally Posted by FONRDAY
(Post 11558122)
If I do I guarntee Ford will pay for the repair or they can buy it back:-jammin
the problem is so few and far that most of the dealerships havent even heard of the problem:-whud
Rickatic knows that battle first hand.
Dieselcraft.com Diesel Fuel Purification Systems portable and tank water detectors at above site; plus polishing, filters, etc. Water Test for Diesel Fuel || Fleet Biodiesel http://www.fleetbiodiesel.com/dropbo...structions.pdf Fleet Biodiesel Diesel and Biodiesel Fuel Test Kit Water and Visual Clarity, 12 Tests, Model# FT-0100 | Bio-Diesel Processing | Northern Tool + Equipment test kits at above sites (not really real low on detection level of water; confirms if above 200ppm) KITPLANES Newsline Parkland, note the comment in above link: "Wiebe is also open to experimenting with the probe detecting water in diesel fuel....." I have had my share of electronics projects and don't have time to play anymore; but, perhaps this is something you could capitalize on? Watect 550 Water Sensor Alarm Module New Online Moisture Detection Sensor For Real-time Alarming above is an in-line flow sensor; lots of reading on this company or their sensor if you search: EESIFLO Diesel fuel test kits http://www.velcon.com/datasheet/VFTKits2073.pdf above detects as low as 100ppm water $10/kit is more than I would be willing to add to my fueling costs. Bob |
(Post 11558320)
Dealership's "never hearing about it" is something i consider a lame excuse. It goes along with "We called ford, and they never heard of any similar issue." I can't speak for everyones eperience, but I remember several years ago, a friend of mine took his 6.0 L 350 in cause the EGR malfunctioned and the intake was oiled and sooty, and they replaced almost everything except the engine itself. They're recurring comment was: "Geez, I can't imagine what you did to this truck, we've never seen any problems with this engine compared to other engines, oh well, at least we took care of you." And when he asked if they had any other 6.0 l trucks in for repairs, and if so, what type? : "Oh no, ford really got it right with this engine, it's a keeper. We haven't had any issues with it at all. " And I'm one of the few that believes the 6.0 engine isn't nearly as bad as some think. |
Besides oil leaks I would of kept my 6.0l but o love my 6.7l more lol :-drink
(Post 11558122)
Regards |
If ford treated me like that you wouldn't ever see another ford in my driveway. ;)
Are these the guys that build ford engines? http://blogs.cars.com/.a/6a00d83451b...ecd7970b-800wi |
