Originally Posted by PROSTOCK
(Post 13540164)
I've got 45K on my RH box and no problems, fixed the issue and have been real happy. Sorry to see others not as lucky(?).
I need another for my '65 and was set on RH, maybe no? |
(Post 13540164)
I need another for my '65 and was set on RH, maybe no? I am happy with my new one (warranty) my steering it tight now. That being said I did have one failure so I can't say if it was just a fluke or a problem until I put some miles and abuse on this one and see if it holds up. I about ran over the curb on my first test drive after install because sheesh the truck turned when I moved the steering wheel. |
Great to hear! With as much slop as we seen in your last box I bet it is like a whole new truck!
Sloppy boxes are no fun! :D LOL |
Originally Posted by sammie0126
(Post 13540378)
Originally Posted by EXv10
(Post 13540341)
Just another rebuilder, I would get one from the parts store for convenience.
(Post 13542343)
OH yea? That's where I got the one I have now and the output shaft bushing / bearing is completely gone. Don't want to repeat that. This truck only sees about 500 miles a year, it's not like this box has a lot on it now. Lifetime warranty is great if you don't mind replacing it for a lifetime. I like one and done...
I'd like to rebuild my own, bore out the housing, install the bearing, new balls and stuff, great fun!
Originally Posted by Snowseeker
(Post 13543534)
I got my core back today on my warranty replacement and also got the email Harvey had promised. Now take it for what's it worth but at least he did send me a note on what they found.
<!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]--> In your case, there was a pin in the valve that came loose. That's what was causing the play. Thanks, Harvey |
Originally Posted by Bigpipes 35
(Post 13544245)
A new career in you future perhaps...:-X03
If I could get 3-4 done per day maybe. |
(Post 13537192)
As a matter of fact:
https://www.ford-trucks.com/forums/p...ctureid=104744 https://www.ford-trucks.com/forums/1...rebuild-2.html I personally wouldn't want anything in my cooler lines that could block up and stop flow. |
So with no new posts I'm assuming the new box is working good? Hope it is. Would you buy another one? Thanks for all your helpful threads.
Since my second power steering pump, I've had no more woes. It wasn't a red head issue, just bad luck with the first ps pump.
Where is a good place to get a PS pump? Ford, cheap parts outlets or another place?
Originally Posted by wpnaes
(Post 14256785)
I went to RockAuto, a sponsor here, but don't get the cheapest one there. Also ordered 2 new hoses, but not the hose to the reservoir.
