Why are some needles red/orange and some yellow? mine are all yellow.
Originally Posted by FordFETruck
(Post 12737574)
If you notice in '86 F150 picture here the transmission selector dial is the correct factory color. This is because the needle on the selector isn't painted, it's plastic. Less likely to fade and change colors. http://i1227.photobucket.com/albums/...T/100_5907.jpg And the needle here on my radio dial doesn't see as much sunlight... https://www.ford-trucks.com/forums/p...ictureid=67270 |
I just realized mine was that way. Maybe some day I will paint mine, but it looks like a major pain in the butt, or do the needles come off?
(Post 12737634)
I wouldn't take them off anyway. How I paint the needles is I got a Fluorecent Red Paint Marker, (Testor's #2575 or equivalent) and using an index card, slip the card in back of the needles and paint. You can do the same with a small detailing brush. The trickiest needle to paint is the speedometer needle. It has a circlular shape around the base of the needle that needs careful steady hands to get right. |
How do you get the plastic shield off from over the gauge cluster?
(Post 12737723)
Originally Posted by 81-F-150-Explorer
(Post 12737569)
I always use flourecent Red paint. That way the needles will reflect the blue and green light back at you. Also after awhile after the paint fades it will look very close to the factory needle color and stay that way for a long time.
Just using regular red paint will make the needles look black at night because red paint needs red light to reflect the color back to your eye so you can see it. Stock colors are blue/green light. Those colors are absorbed by the plain red paint and therefore turn black at night. Fluorecent colors radiate or glow off any color of light including UV light (Black Light). |
(Post 12737833)
That would explain why my red needles don't turn black at night - I don't have the filters on the bulbs so I'm getting the red end of the spectrum as well as everything else.
Also why your dash lights are 1/3 brighter. White light is a mixture of the three primary colors of light. Red, Green and Blue, just like on your TV set or computer monitor. Filter out red, and the brightness is reduced by 1/3rd. (I used to be a stage lighting engineer when I was younger pup, and is why I still know all this) |
Well I drove my truck down the freeway for the first time today, ran great. THAT WAS LOUD! I noticed after I got off the freeway I had 35 PSI oil pressure at idle, on the throttle it's always 55 PSI. When I got back on the freeway to head home I was peeling out a bit around the corner hahahaha. That thing needs a different cam, lacks torque.
So, what range of light, meaning from infrared to ultraviolet, do the warm white LED's give?
(Post 12738089)
Warm white light is phase shifted toward the red end of the spectrum, but shows the full spectrum of light. Just has a little more red than the other colors. Cool White light is just the opposite, it's phase shifted toward the blue end. |
I understood that was the case on the warm and cool white incandescent bulbs, but didn't know if the LED's gave an even range of color or if they favored a particular color.
The needles on mine were faded to white. So I just used what I had and brushed them yellow while it was apart.
(Post 12738195)
From what I understand LED's tend not to favor any one part of the spectrum. Uses little power so resistance is not an issue. But it all depends on what the bulbs were designed for. For the light to look warm, or look cool for that matter, the light spectrum has to be shifted toward one end or the other of the spectrum. This can be done with external filters or with the bulbs themselves and varying power sources. Filters are easier, more efficient and uses less energy to create desired colors, even though a part of the energy is wasted. To create a blue incandecent bulb for instance without a filter would require a lot of power and a highly resiliant filament otherwise it would burn out too quickly. Why most bulbs that are colored without filters are of the gas "neon" tube type variety. LEDs are a little beyond me though. They were not used and barely thought of when I was working on stage lighting. |
Should we have a discussion about kelvin temperature?
LED's can have filters or the color can be biased by doping of the semiconductor. Slightly differing formulas will occur even within the same batch. These are then 'binned' according to actual output. Some real LED geeks over on Candlepower. LED Flashlights http://www.candlepowerforums.com/vb/...lar-White-LEDs |
