Originally Posted by HIO Silver
(Post 9210843)
Personally, I connected the electric choke (Edelbrock 1406) to the "S" (stator) terminal of alternator.
Is that the terminal on the starter solenoid mounted on the passenger fenderwell? I haven't had to touch the alternator yet, so I'm unfamiliar with how it's setup on the truck.
~B |
Originally Posted by piratius
(Post 9211120)
~B The "S" terminal is on the back of the alternator. I has either a terminal post (with a nut and star washer) or a plug connector. The alternator housing is normally cast with the terminal designations. Using the S terminal is easiest... abotu 18 inches of wire and a terminal connector. It'll be the best 10 minutes spent towards your truck's driveability. GO FOR IT. |
(Post 9211153)
Also - for the ground on the E-choke, I can just put a short little wire to one of the carb -> manfold bolts, yes? (Asking because I already ran one!) ~Brad |
I got my Tranny cleaned and the 1st coat of "dark ford blue" paint on it, I also got the doors stripped down and ready to go to the painter. I found that my vent window frames was somewhat rusty so I guess I am now looking for a couple rust free vent window frames.
(Post 9211226)
Sweet. Can definitely do that. Unfortunately, the PO disconnected ALL the choke hardware (no clue why!!), so the linkages and stuff are WAY out of whack. Meaning, of course, that I have to try and figure out how it's supposed to be setup. (I'm also assuming the electric choke is still actually good...and with the previous owner, assuming can be deadly!)
Also - for the ground on the E-choke, I can just put a short little wire to one of the carb -> manfold bolts, yes? (Asking because I already ran one!) Yessiree... POs are notorious for doing "repairs" that makes me wonder why they even bothered. My take is "Don't be one of those POs that FTE members bad-mouth if ever you sell your Dent". Journeyman workmanship adds value to your truck!! To keep inline with this thread, I filled up my gas tank and took the F-Bomb for a short drive... it definitely needs an alignment. |
I tore down my 76 highboy. Only thing left is the chasis with engine and tranny. Trying to decide what to do with them. I have a fe block with a NP 4 speed. Not sure which motor it is the only id I can find is a 352 on the front of the block.
i put a set of bucket seats in my supercab a couple of weeks ago
http://i54.photobucket.com/albums/g8...ewseats001.jpg http://i54.photobucket.com/albums/g8...ewseats002.jpg |
few months worth of mods
hey guys sorta new here at posting on FTE.. but wanted yall to check out what ive been up to these past few months. got about 50mi's on her after break in and boy does she sound mean. was rebuilt by previous owner 30k miles ago with unknown specs other than from 351m to 400. but doing my mods i noticed that he had aftermarket upgrades (cam, pistons) but lifter went bad on me and inspection told me it was my cam :( stock exhaust broke in half too all in same week.. and on top of that exhaust manifold bolt broke along with easy out.. so this is what drove me to these :)
MOTOR MODS: swapped in 2178 edlebrock cam, dual roller timing chain cover, cyl heads checked for flaws minor port/polish cleaning.. hardened valve seats(d5ae a2a heads), lifters, springs, flowtech long tube headers 32" x 1 5/8" into 2 1/4" flowmaster pipes/mufflers.. INTERIOR MODS: custom gauge cluster, GT grant wheel, roll on bedlinered the floor boards/under seat. check out pics in my garage :) i cant figure out how to load pictures into posts MORE MODS TO COME! |
Ordered my engine today from pheonix engines. Went with the turnkey, phase 1 351w 321 HP. Should be a nice daily driver. Now time to get the headers,starter,alt,P/S pump, brake booster and master cylinder ordered. My 3rd member and axles are ready for me to pick up tomm. so hopefully tomm. I will have a rolling chassis.
Originally Posted by emeraldcoupe
(Post 9215812)
Did the 3G alternator upgrade with a 130 amp alternator from a 95 Taurus. I posted these pics in the thread about 3G upgrades too, but hey you can't have too many pics!!
https://www.ford-trucks.com/user_gal...id=233703&.jpg https://www.ford-trucks.com/user_gal...id=233732&.jpg |
Rebuilt my carb, blew a power valve. hope that fixed the problem!
:-partybud |
(Post 9215812)
http://i54.photobucket.com/albums/g8...ewseats001.jpg http://i54.photobucket.com/albums/g8...ewseats002.jpg ty:) |
Originally Posted by TruckGirl74
(Post 9218464)
have you replaced the seats in the supercab yet? or are you? I really want to and hoping someone has already has knows what fits well, any suggestions would be great
ty:) |
