Oil change and greased every grease zirt I could find. Then washed all the nasty dirt and salt off of her. Took the windshield wiper arms off to polish them for *****s and giggles.
slider
1 Attachment(s)
for valentines day my wife and I got out of town last weekend. She went roaming thru craft shops as did I. Yup, you guessed it, the junk yard. I scored a slider with gasket out of an 86, temp sensor and ecm for her 2000 Jimmy for $69.
Yesterday I replaced the broken latch on the slider and swapped it in. |
sleeper
2 Attachment(s)
I acquired an old pick up sleeper a few months back and have been picking at it for a while. The plan is to have a place for the dogs to ride and not loose bed space, plus I have always liked kidnappers.
This one was intended to fit a late model Chevy but i will be able to make it work. I will need to add spacers underneath to align the rooflines and rework the window opening at the cab. I thought about cutting the front loose and reglassing it to match the cab angle but i just need it out of the garage right now. A 2x4 brings it up to the correct height so I'll make a frame for it to sit on and help with the anchoring to the bed too. And the supervisor had to check to see what I was doing to her truck. |
I installed a new steering wheel wrap. Cracks kept catching on my wedding ring plus they were just annoying. I also fixed the horn button itself. It was pulling away at both ends.
https://cimg1.ibsrv.net/gimg/www.for...1408686087.jpg |
https://cimg8.ibsrv.net/gimg/www.for...9306d95d0c.jpg
I installed a aux NOS gas tank on my Supercab https://cimg9.ibsrv.net/gimg/www.for...142a0807f9.jpg I replace the turn signal lamp sockets |
mocked up my disk brake
4 Attachment(s)
nwf disk brake kit np205,time to get a drive shaft
http://i1378.photobucket.com/albums/...psihon2yod.jpg http://i1378.photobucket.com/albums/...pslr4f7sni.jpg http://i1378.photobucket.com/albums/...ps14k3ikp4.jpg after letting it sit for 6+ years I spent today cleaning all the mildew off the outside & all the mice nest & spider webs out of the inside
Copper truck:
Changed the valve cover gasket, PCV grommet and PCV valve. Changed the oil and filter Replaced the busted fan shroud: https://www.ford-trucks.com/forums/1...l#post16965684 Cleaned-up the toolbox and put all the tools away. Again... |
I gave her the first bath since I've owned it.
https://cimg8.ibsrv.net/gimg/www.for...bccda66917.jpg 1rst Bath |
Cleaned out the tow tray:
https://lh3.googleusercontent.com/qu...Q=w640-h480-no Found a lot of useful gear in there, too, including the headlight surrounds and the radiator shroud. Plus a stack of old tools... gotta love old tools! - boingk |
Replaced the drive shaft carrier bearing, no more rattling, woohoo!!! Also found a new way to pull the carrier bearing since I have broken quite a few 3 jaw pullers getting them off. Use a OTC heavy duty pitman arm puller, works awesome.
today
2 Attachment(s)
Seam sealed the bottom of donor cab, painted it with POR 15 and then top coated it. Placed it on the frame today at lunch time. Lots more still to do!
Not a damn thing...........:-arrgh
I changed my spark plugs....and now it also has a nice lope to it}>https://cimg1.ibsrv.net/gimg/www.for...b9c59fdee7.jpg
https://cimg3.ibsrv.net/gimg/www.for...939cfd4e2e.jpg https://cimg5.ibsrv.net/gimg/www.for...1f08cf6c19.jpg https://cimg0.ibsrv.net/gimg/www.for...9ee4429cfc.jpg |
Dasher, that there is a purdy truck!!!
