Originally Posted by Djstright
(Post 16901456)
Well I got the flywheel back from the machine shop and ordered a ton of new parts including a new heavy duty clutch and water pump. Now the entire cooling system will be new. https://cimg9.ibsrv.net/gimg/www.for...0f5ff1a658.jpg
Which machine shop in AB did you use? |
Originally Posted by Aaron-71
(Post 16902531)
Looks pretty good!
77: bought a new oil filler plug, pcv elbow and heater hose elbow. Fashioned a filtered fresh air intake for the pcv system. Changed the power valve in the carb. Adjusted the idle mixture screws. Adjusted the curb idle speed. Checked and replaced taillights
78: checked and replaced taillights. Adjusted the brake lamp switch. Hauled off the cardboard to the recycler. Swept out the bed 79: checked and replaced taillights. Cleaned out the bed Cleaned up the driveway, put away all the tools and supplies. (Not that I'm done with them, but at least I'll be able to find everything...) |
Originally Posted by PapaBearYuma
(Post 16903694)
Got around to getting the exhaust done this morning. True duel, two and a half inch pipes into Flowmaster super 40 series. Exits out in front of the rear wheels. Sounds a lot better than the rusted out set that was on it.
I found out it shows 1/8 of a tank left when it runs out of gas. I killed the battery trying to get gas to the carb once I filled the tank. I got it towed at AAA's cost to a mechanic who put her on a charger and eventually got it up, running and on to work a couple hours late. So at least I know where empty is now.
Replaced my old rusty bumper. Fit is not exactly what I wanted but will do for now. Later I'll remove and modify the brackets to move it up and in a bit.
https://cimg6.ibsrv.net/gimg/www.for...d13371f3ef.jpg https://cimg8.ibsrv.net/gimg/www.for...d4ff028ecc.jpg https://cimg1.ibsrv.net/gimg/www.for...f09baad45b.jpg https://cimg4.ibsrv.net/gimg/www.for...e42fa496ab.jpg |
1975 F100
5 Attachment(s)
I’ve been working on my 1975 F100 the last couple days, when I get a chance. I removed and recovered the bench seat and cut out the rusty passenger floorboard. Today I’m hoping to do more prepping to the floorboard to get it ready to weld in the new pan. Wish he luck! HAHA
Gene |
Man, that’s nice paint color on your truck. ME LIKE!
Originally Posted by drumgene
(Post 16905062)
Gene |
Actually, I got lucky and found it on eBay in a damaged box. Only paid $100!
2 Attachment(s)
Put the core support back in.... finally making progress again!
Installed the new cowl windlace from Bronco Graveyard. It's one clip too long but I remembered reading that somewhere so wasn't too surprised. Also bought 25' of 5/16 steel tube to make new cooling lines for the transmission.
Michael |
1 Attachment(s)
I washed ol blue today to sale it....the guy was on his way tomorrow with CASH. :'( That makes the second time I have done that....
I came to my senses 10 hrs later and he understood it was a error in judgment on my part. |
