Originally Posted by lakequ
D = 330 2V Heavy Duty FT engine. C = Oakville Ontario Canada Truck Assembly Plant. G35101 = 1969. 156" Wheelbase. COLOR: Blank.* F610 = F600 (gas); 21,000 lbs. GVWR F 8 = This F 8 seat upholstery color/material not listed in the parts catalog for 1969. It might be Green Vinyl if the truck is a Custom Cab (1970 listing). O = Fuller model T-905-B 5 Speed Direct or New Process model 541 5 Speed Direct. F3C: F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity. C = Ford Rockwell-Timken 6,000 lbs. Capacity Front Axle. 21,000 lbs. Gross Vehicle Weight Rating. 164 net HP @ 3,800 RPM 470002: 47 = Cincinnati OH Ford District Sales Office, where the original selling dealer ordered the truck from. 0002 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." *When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the purchasers order, making it a Domestic Special Order. |
thanks number dummy
Please decode this VIN, Thanks in advance NumberDummy.
There's no guarantee that I'm reading these codes correctly. By the time I'm through, my eyes will resemble Mr. Magoo's! W95 = NT950 (Diesel). D = Cummins model NHE-195 743 cid 6 Cylinder Diesel. U = Louisville KY Assembly Plant. B12153 = 1967. 194" Wheelbase. COLOR J = Rangoon Red. MODEL W952 = NT950 (Diesel); 49,000 lbs. GVWR BODY 681: 6 = Black all Vinyl / 81 = 81A Standard Cab. Domestic Special Order TRANS - DRIVESHAFT - FRONT & REAR AXLE listed on the separate plate. MAX GVW LBS = 49,000 lbs. Gross Vehicle Weight Rating. CERT NET HP 184 @ 1,950 RPM DSO 220210: 22 = Charlotte NC Ford District Sales Office, where the original selling dealer ordered the truck from. 0210 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." |
1974 F 699
I appreciate all your interpretations. Amazing!
I have the following numbers on the door tag:VIN: F61DVU21635 TYPE GVW: F613 TRANS: 0 AXEL: E3L Thanks a million! |
1974 F600
Originally Posted by DeRock1106
(Post 17911376)
VIN: F61DVU21635 / TYPE GVW: F613 / TRANS: O / AXLE: E3L D = 330 2V Heavy Duty FT engine. V = Kentucky Truck Assembly Plant. U21635 = 1974. F613 = F600 2WD (gas); 22,000 lbs. Gross Vehicle Weight Rating. O = Fuller model T-905-B 5 Speed Direct or New Process model NP-542-FL 5 Speed Direct. E3L: E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity. L = Ford 6,000 lbs. Capacity Front Axle with Power Steering. :-X22 |
(Post 17911272)
Geez Louise, even with a 27" screen and a magnifying glass, this pic is so tiny that I can barely read it. Post a LARGER pic next time.
There's no guarantee that I'm reading these codes correctly. By the time I'm through, my eyes will resemble Mr. Magoo's! W95 = NT950 (Diesel). D = Cummins model NHE-195 743 cid 6 Cylinder Diesel. U = Louisville KY Assembly Plant. B12153 = 1967. 194" Wheelbase. COLOR J = Rangoon Red. MODEL W952 = NT950 (Diesel); 49,000 lbs. GVWR BODY 681: 6 = Black all Vinyl / 81 = 81A Standard Cab. Domestic Special Order TRANS - DRIVESHAFT - FRONT & REAR AXLE listed on the separate plate. MAX GVW LBS = 49,000 lbs. Gross Vehicle Weight Rating. CERT NET HP 184 @ 1,950 RPM DSO 220210: 22 = Charlotte NC Ford District Sales Office, where the original selling dealer ordered the truck from. 0210 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." Sorry about the picture size, it wouldn't let me resize it. Does the T of NT mean factory tandem axle? This one appears to have had the frame welded on both sides and maybe the tandem added. |
Originally Posted by Corn73
(Post 17911686)
Who installed it and how it was done is unknown, as the records are no longer available. The Fuller RT-915 15 speed transmission (usually installed in W/WT1000D w/a diesel), front axle and driveshaft were also Domestic Special Orders. |
Thank you so much for your time and knowledge. Just two more questions please. *Would the first three of the Vin for a '63-69 N1000 be W10? *I know two of the three diesels offered were the Cummins 195 and the Detroit 671, but what was the third? Thanks again. |
(Post 17923422)
Thank you so much for your time and knowledge. Just two more questions please. *Would the first three of the VIN for a '63-69 N1000 be W10? :-huh No such thing as W10. 10 = 1/2 ton truck. *I know two of the three diesels offered were the Cummins 195 and the Detroit 671, but what was the third? :-huh Only two are listed. Cummins: 1963/69 // Detroit: 1968/69. |
Hello, I’m hoping that the forum will shrink the picture down. Im looking for the exhaust manifold with a T4 turbo flange, and gaskets, Also a intercooler pipe. Pleqse advise. Thanks, ky https://cimg3.ibsrv.net/gimg/www.for...36ec47c8c.jpeghttps://cimg5.ibsrv.net/gimg/www.for...f7c509711.jpeg https://cimg6.ibsrv.net/gimg/www.for...eea5f24e5.jpeg |
Why to you want a T4 manifold for that small of a engine?
As for the pipe, a salvage yard for shop that can cut out the bent section and weld in a new piece. |
Have a s366 turbo on it. |
How laggy is that?
Not to bad. Runs good when it lights up. I would like a little bigger p3000. |
