pulled the dash off ,sanded and hit it with paint ,looks like im gonna have to find a new harness and rewire the truck ,ill send pics
I am going to attempt it in my 75 degree driveway this saturday morning! Lol, I am glad I am not in that situation again. Thanks for having the axle I needed last year. Can you believe thats been over a year ago?
I got (what should be) the last of my lights installed on my 84 F250 flatbed last night. REALLY lights up the night!
Light count: -25 running/clearance lights -6 stop/tail lights -4 fwd facing flood lights -2 rear facing flood lights -2 head lights :D http://i650.photobucket.com/albums/u...ps4effce33.jpg http://i650.photobucket.com/albums/u...ps61447627.jpg http://i650.photobucket.com/albums/u...ps2dce59ba.jpg http://i650.photobucket.com/albums/u...psd9768e58.jpg Took it out last night to aim the spot lights and they picked out 3 deer in the field at about 150 yards. I guess they are doing what I designed them for! haha |
Bump187, that truck looks wicked good. Reminds me of big rigs with a ton of lights. :-X22
bump187, it looks festive. It will be nice around Christmas time to match all the Christmas lights....:-X22
Had an interesting day with my 85 today.
Went to the parts store and picked up a modulator valve for the C6. On the way home, I mashed on it and when it hit 3rd(about65mph) Smoke rolled out the back and I lost a LOT of power. First thought; Sucked up a valve. When I pulled over, still smoking, I checked for oil in the water,water in the oil,etc. When I pulled the dipstick on the tranny, about 1 qt low. When I took the vac line off the modulator valve, ATF ran out. Luckily, I had a few tools and some ATF behind the seat. Changed the modulator valve on the side of the road, filled up tranny. Smoked for quite a few miles but made it home. Now is time for new plugs....Trav..:-X04 |
Originally Posted by truckertrav
(Post 12292303)
(Post 12292327)
But, think of how clean the upper end of the engine is now! That's just the same as running SeaFoam through it. One quart of ATF should clean out a lot of carbon. :-X22
That'll keep rust down for a while.... I was concerned at the time but now I am really happy...Trav...:) |
I'm still messing with my carb. I had put a bigger metering rod in the carb (YFA) and it still seems to be running rich. Double checked the float setting and checked the check valve ball and weight.
The auto choke and the butterfly in the air cleaner are opening as the motor warms up.The darn thing still shuts off every so often when you let off the gas to stop or slow down. This seems to happen when I first start driving. After the truck runs a couple miles it is ok. It sometimes starts right back up and other times it has to crank and crank. I've replaced the fuel pump,filter, all the old rubber gas line pieces I could find and have tried several different carbs ,nothing helps. When it is running, it smells rich but when it shuts off on me it seems like a lack of fuel. Another thing, it won't run worth a hoot on reg. gas. It diesels when shut off and pings when driving on reg. gas. Basic timing is 10 deg. Vacuum is approx. 17-18 at idle. I've been known to have a senior moment now and then. Is there something I'm missing? |
Originally Posted by old409
(Post 12292508)
The auto choke and the butterfly in the air cleaner are opening as the motor warms up.The darn thing still shuts off every so often when you let off the gas to stop or slow down. This seems to happen when I first start driving. After the truck runs a couple miles it is ok. It sometimes starts right back up and other times it has to crank and crank. I've replaced the fuel pump,filter, all the old rubber gas line pieces I could find and have tried several different carbs ,nothing helps. When it is running, it smells rich but when it shuts off on me it seems like a lack of fuel. Another thing, it won't run worth a hoot on reg. gas. It diesels when shut off and pings when driving on reg. gas. Basic timing is 10 deg. Vacuum is approx. 17-18 at idle. I've been known to have a senior moment now and then. Is there something I'm missing? As for the rich condition, is there a chance that the timing is so advanced or retarded that it is causing a lack of full combustion? Toward that end I'd address the pinging/run-on situation first and then move to the fuel system. By the way, WCFB's were good carbs! Then the AFB improved on that, as did the AVS. And for trivia, what was Carter's first name? What does the "F" stand for in WCFB and AFB? Ditto the "A" in AFB and AVS? ;) |
I replaced the stat and timed it using a vacuum gauge ,thinking the balancer/timing mark might have slipped. I think I'm going to go over everything again this weekend and see if I might have mis-read something or screwed up on something.The frustrating part of this is,,,,I know the problem is mine,something I didn't do or didn't do correctly.
On the AFB, didn't AFB stand for aluminum four barrel. I had a lot of AFB's through the years.I've had faster cars through the years but there was never anything like the dual AFB's sounding like they were going to suck the hood right down through the intake on the 409 I had. The WCFB,,,,I think a 1956 Chevy I had may have had one on it but I never messed with it. From what I've read it looks like the WCFB used the same type metering rods as the YFA. |
Will Carter Four Barrel = WCFB
Aluminum Four Barrel = AFB Air Valve Secondary = AVS Yes, two AFB's sounded awesome! Good luck going over everything. It has to be something simple. |
Hey, Shaun, read this
2 Attachment(s)
Originally Posted by Fordzilla80
(Post 12285737)
Just fired off a few emails to salvage yards across the US concerning 1980-1981 4x4 trucks they have in stock. Let's hope at least one of them has the T-Case handle I'm looking for. :)
Originally Posted by ctubutis
(Post 12294990)
I'm not sure what you're looking for, but here is the 1981 in my ex-favorite yard. Somebody already took the boots; I had asked Gary last weekend how to get the things off as they appeared to be screwed in but yet covered by rubber, seems somebody else already figured it out. :(
I already have the boot, so that's not a big deal at all. As for how they're held on, you have to raise the rubber flaps to access the screws. Just remove the four screws, and the boot should lift right out. ------------------------ As for what I did to my truck today, I bought an NP208F for it. Picked it up for $40 from an 82 F150 that a guy on Craigslist was parting out. He said it worked fine when he last drove the truck, and when I bolted it up to my transmission, it does go into all the gear ranges, and the yokes move accordingly. However, the front yoke feels a bit sloppy, so there may be some chain stretch going on. http://imageshack.us/a/img163/7536/picture790d.jpg |
Not a bad deal there fordzilla
