Originally Posted by Bullitt390
(Post 14368712)
Unfortunately that isn't convenient.
Does make me wonder when back in the day a guy would replace a cooler, end up with high temps again, blame casting sand or some other voodoo, replace with another cooler and be right back again with high temps. Then the guy disappears from the forum when all along he may have had a bad bypass valve. D'Oh! We know better now :-jammin But, all things considered if one has a high temp spread, replaces the oil cooler and knows they did a pretty good job during the flush... and ends up they still have high temps, it just might be the bypass. Josh |
So I ran for a while without a bypass valve. Yep, I missed putting it back in after an OC install. It was mixed up in a bag of parts with a fuel pressure spring kit.
Well I knew something was wrong when I pulled my filter for a quick oil change and it was dry. Found then valve and spring and reinstalled it. Without the bypass valve, temp spread was around 12° on a test. With the valve installed, temp spread bounced from 6-7°. Of course, this was an aftermarket OC. I just replaced it again with a factory kit and my spread now is 4-5°. |
Originally Posted by jswartz84
(Post 14368839)
Originally Posted by Splash67
(Post 14368937)
So in your scenario there was no valve to stop the oil from going to bypass and you were still getting cooled oil? how long did you drive this way and how much temperature testing did you do? I'm curious about the exact opposite...plugging the bypass and not allowing the oil to bypass for any reason at all.
I'm thinking (rather slow right now) that under normal conditions the valve will be closed. |
(Post 14368954)
My test was about 6k miles over 9 months, both towing and not, watching my temps all the time. I was mainly scratching my head wondering why my spread was so high. I did notice that my EOT fluctuated more, and pulling off the freeway the EOT dropped quicker.
I'm thinking (rather slow right now) that under normal conditions the valve will be closed. Anyone have an opinion about AM coolers and the need for the bypass? I'm pretty sure that most remote cooler set ups do away with the bypass altogether. |
When towing 7K, on a hilly interstate in PA i was consistently hitting 245deg F and on long uphill, I hit 255deg F. Is that considered "very hot?" What is the threshold for thinking that I may have a problem?
As an aside, I am having the flush done this week and installing a coolant filter. |
Originally Posted by Bordeauxman
(Post 14370197)
As an aside, I am having the flush done this week and installing a coolant filter. I fully suspect that the new cooler will do the trick, but I'm reading and preparing for plan "B" incase the AM cooler doesn't do it. |
(Post 14370370)
The max I'm allowing Monster's oil to see right now is 225°F, because of that I have basically parked her until I have solved the issue.
I fully suspect that the new cooler will do the trick, but I'm reading and preparing for plan "B" incase the AM cooler doesn't do it. <a href="http://s842.photobucket.com/user/Splash67/media/Monster%20-%20March_April%202014/20140522_225214.jpg.html" target="_blank"><img src="http://i842.photobucket.com/albums/zz342/Splash67/Monster%20-%20March_April%202014/20140522_225214.jpg" border="0" alt=" photo 20140522_225214.jpg"/></a> |
What the hell is that?????
Originally Posted by npccpartsman
(Post 14372113)
Nope... Replaced the oil cooler and still have high EOT...maybe I'm going to be the guinea pig and try blocking the bypass...what's the downside?
(Post 14375898)
Josh |
(Post 14375921)
Possibly not much now, but cold oil and cold ambient temps equal high oil pressure which the oil cooler must not be able to handle.
Josh I not in the mood to pull the turbo again this weekend so I think the next thing I can address is the bypass. If I were to replace the spring with a solid stud then I could confirm that the bypass is the problem. Once I know that I can decide what to do long term...maybe a new cover or a full bypass setup. |
Well here goes... I'm taking the filter housing off today and putting a solid stud in place of the bypass spring. If I'm reading the oil diagrams correctly that should make the oil go through the cooler by taking its other paths away.
Feel free to let me know if I'm missing something. |
Well is FrankinOilstein alive yet?
