3 Attachment(s)
I installed my power steering box last night in my 1977, 2wd f150. I also will be working on my header installation. Since I was alone during this installation I had to come up with a self help idea, I just thought I would share. After running a tap and die on the bolts & box, I screwed two bolts in the steering box from the opposite side. This allowed me to place the box on the frame and hang in place for installation. next I installed the third bolt correctly through the frame and into the box (only snug). This allowed me to remove one bolt at a time from the box and and snug them into place until the box was ready to tighten down.
I thought this may help someone in the future. If the exhaust was in place, I would have used set screws 7/16-14 (?) x 2" to set the box in place. I will use (2) 3/8-16 x 1" to set the headers in place. |
4 Attachment(s)
Well, I charged my Vintage A/C this morning.
Attachment 289220 I am setting up my new DTS 9" Rear End (35 Spline / 3.50) with soft lock Detroit, Stange Axles and race studs with Wilwood disc brakes. Hope to have this in my truck by this weekend? Attachment 289001 Attachment 289000 This 9" is not looking too good...fortunately it's out of a 77 I am in the midst of framing off.... Attachment 288719 That's what I have done and am doing today... |
more work on Rusty
1 Attachment(s)
Yesterday was busy. New master cylinder arrived thursday so t got bled and installed. Tried to remove the broken bleeder screw in the passenger caliper but only succeeded in breaking an easy out. Tried welding a nut to it but it broke off too. tried a couple more times but its only coming out in pieces. I'm now below the surface so I'm hesitant to try welding it again.
The rag joint was shot so I took the remains out and went to the local parts store and a new one is in the $50 range and special order. I looked on the HEP rack and found a new insert for $13, part number 31000. Clean, repair, install. In the process i found out why Rusty starts in gear, NSS switch is dangling by the reverse light wires and NSS wires are cut and tied together. The mount for the NSS is missing. I also dropped and drained the mid-ship tank. 5 gallons of orange gas came out. I poured a couple gallons of fresh gas in and gave a quick rinse. Looks good. Re-installed with new fuel lines. But for those interested, I did find the factory camper wiring plug on the frame. |
Sanded down the lip of two of the rims in the truck. Could not get old water spots and oxidation off.. Came out pretty nice. Used 120, 400, 600 and finally wet 1000 and then polished them with polisher attachment for grinder.
https://cimg6.ibsrv.net/gimg/www.for...436af12a26.jpg |
Got some wiper arms from a 95 ford pickup and modified them according to Tbear's instructions. I shortened the arms about 3" on driverside and 3 1/4" on passenger side, painted metallic silver and installed with 16" rain-x latitudes. The springs are stronger and the arms are easier to remove/install. The whole idea is to have the ability to use 16" wipers without them hitting the edges, which makes for more of a selection.
I also got a decent set of door weatherstripping from the same truck and installed it. The newer truck seals do not use adhesive and the seals just push on. |
Changed the leaking heater core,,,,,,,was not half as bad as I thought, took about an hour including cleaning it up.
More bodywork, did a wee bit of carb tuning, still fighting occasional backfires, but it is pretty drivable now. Drove it to grab some oil. She's a happy truck!
Found a replacement grille shell to replace my beaten up crashed shell, painted and installed 73-75 grille inserts and straightened the bent front bumper
https://cimg4.ibsrv.net/gimg/www.for...a92a4d6b14.jpg https://cimg5.ibsrv.net/gimg/www.for...50f531c032.jpg |
Listed some parts on E-Bay
I listed a "CUSTOM" glovebox emblem, glovebox latch, and OEM matching lockset with glovebox locking latch on E-Bay. I also cleaned and polished another glovebox latch and glovebox cable in my vibrating rock polisher. Looked for Duraspark II wiring and 2G harness for my '66 Flareside. Tacoma Pick n Pull Ford trucks were picked clean
Nearly finished wiring and ready for light check... and then start. I hope.
Received the first of several goodies to tackle engine stuff soon thereafter. Trans fluid and cooler flush, radiator and heater hoses, thermostat and waterpump. Figured since I'm degreasing everything and nutting and bolting everything the PO(S) did, I might as well do the pump. This is judging by the outstanding job he did with all the other "mods" he did. |
Originally Posted by Roger C
(Post 16160891)
Did some good work today. Bedlinered the bed, prepped the hood and cab for paint, and got it running well.
Originally Posted by Murphy's Law F-150
(Post 16161382)
On sat I got all the stuff for both trucks (blue & silver) oil changes. Found out that O'Reilly's price matches Wally World, so I got my oil WAY cheaper.
Got the temp sensor and all 3 belts (alt, P/S, and a/c) changed on ol silver. Temp gauge works now, and no more squalling belts. I think they were original 77 belts? |
Here are some pictures of my work today. I also welded up the completely trashed antenna hole (pictured). Other things I did were to accidentally run over my broom. Still works.
http://i32.photobucket.com/albums/d4...psfzwws1hb.jpg http://i32.photobucket.com/albums/d4...psdezrovku.jpg http://i32.photobucket.com/albums/d4...psuugw4w2s.jpg |
