thanks for the quick reply. the number should have been written as f70dc778441. thanks for the help. would you know the parts number for a four barrel intake to fit the 330 v8.
Originally Posted by farmen4fun
(Post 17070029)
Vin help
I am buying a f700 from 1980. Vin is F70HVHK0078. Can you identify the engine for me?
Originally Posted by Skipdog
(Post 17084020)
H = 370 2V or 4V V = Kentucky Truck Assembly Plant. HK0078 = 1980. |
Hey ND are most of the parts between the F700 and F600 compatible?
looking at a steering box swap between 1979 F600 and 1976 F700 Thanks |
Thanks ND!!
Originally Posted by jimmyboy111
(Post 17088860)
A new question for you
(Post 17031879)
The part number will be Ford related.
Pic: Here's the LN applications from the truck parts catalog. You might try Red Head Steering Gears, located in Seattle. thanks |
Originally Posted by gdoakes
(Post 17102233)
ND, again at work and am puzzling over something I found when working on the truck in preparation to move it to its permanent home-the truck has a transmission mounted PTO for the dump cylinder and it appears to have a belt driven, electric clutch actuated small hydraulic pump mounted on the top, passenger side of the engine. I suspect it was added by the truck bed chassis modifier (Aquatech of Cleveland) and I am trying to confirm (without access to my parts manual) whether it could be an OEM install and if it is verify its intended function-could you peruse your 85 manual for the ln700 w/the 8.2l DD and tell me if it could be own?
thanks |
Info. 1992 F700
1 Attachment(s)
Good afternoon.
This is my first post, otherwise I'd post a picture of the vin tag. I'm interested in finding out more on this f700 2/92 Vin: 1FTWK72PXNVA22024 Body:8 Trans:cv Axle:W2 Ext pnt: EC DSO:560118 "Triangle shape" FOTA-15204A10-GA It has a 6.6l 185hp motor in it, and I know the tranny has been changed to a Eaton 13speed. I run a hotshot in a 1 ton dodge but need a heavier drive axle and this truck is available. I've messaged a little bit with neverenufhp and have his thoughts about increasing the horsepower on the motor. The rear end ratios are what I'm really interested in. Thank you. |
Trying to figure out a part # for my fan clutch.
VIN is 1fdxk74p7mva37849 thanks, |
Originally Posted by telescope-tech
(Post 17170757)
VIN:1FDXK74P7MVA37849 X = Class 7 - Air Brakes - 26,001-33,000 lbs. Gross Vehicle Weight Rating. K74 = F700 Diesel. P = Ford model FTO 6.6L (401 cid) 6 Cylinder Turbo Diesel. 7 = Check Digit, FoMoCo usage only. M = 1991. V = Kentucky Truck Assembly Plant. A37849 = 1991 Numerical Sequence of Assembly, the trucks specific serial number. |
I think its a 66, it's gas with a scissor lift bed/dump truck
Vin # F81FUE90712
212 F810 D281 2FBE 30000 199 3800 721076https://cimg4.ibsrv.net/gimg/www.for...f892f10aa0.jpg |
Originally Posted by M00S
(Post 17216325)
Vin # F81FUE90712
212 F810 D281 2 FBE 30000 199 3800 721076https://cimg4.ibsrv.net/gimg/www.for...f892f10aa0.jpg Note that 2 is the TRANS code, FBE is the AXLE code. |
(Post 17220231)
VIN and etc. decoded in your other post on this topic.
