Originally Posted by two4two
(Post 11254441)
This is one of the pigtails on that alternator. Anyone can tell me which NAPA or other parts store part# for the OTHER pictail? (The one at the voltage regulator).
NAPA VRC 441 http://partimages.genpt.com/largeimages/102401.jpg http://www2.napaprolink.com/detail.a...41_0334767532# |
Ryan sells the stator pigtail.
It is the same as the 3G. RJM Injection Tech — Alternator Regulator pigtail https://cdn.shopify.com/s/files/1/00...ge.jpeg?100399 Ebay, PICO WIRING 5702PT Wiring Harness Pigtail Voltage Regulator 3 Pin Tan Ford Ea on eBay! Pico # 5702pt Standard # 5354 |
Faster than me, Rep's denied.... :(
Thank you everyone!!! Both pigtails were bad and had to be replaced. After replacing and making sure I SOLDERED them inline instead of using crimps I put the volt meter across the battery while engine running and volts read 14.6V, battery light is out on dash and volt meter in dash shows 15V. It finally got warm enough to get out and do it and it WORKS!!! Thanks guys. And I guess this thread is resolved and closed.
