Yes, and they were the original black plates, not the new repops that California just started issuing for those wanting to switch.
Stewart |
1 Attachment(s)
Originally Posted by IMASAP
(Post 16531490)
More or less installed my 6.0 trans cooler today. While the grill and bumper are off I may put my Harley style headlights in tomorrow.
https://cimg5.ibsrv.net/gimg/www.for...4d89a23bc2.jpg Attachment 215167 |
Originally Posted by mecdac
(Post 16531424)
My best maths led me to believe that I was outnumbered about 41,367 to 138..Custer may think otherwise.}>
Well, using your common core math (bahahahahahaha) then you are in error, it was a minimum of 140 Atlanta fans. Had to be, you few were doing the chop whenever y'all saw each other. :-X14 On second, thought call me David you SF Philistine Stewart |
Well, the Ex just finished the 12+ hour haul from Salt Lake City, and I am now sitting at home.
The Ex ran perfectly the whole trip. I only once saw the temps jump into the 220 range and the EGT climb above the 1100k mark, and that was when I was flogging it up a steep grade in eastern Oregon in 90+ weather. The Ex seems to be reborn, and it is about time, as my wallet is once again tapped out :'( Now, tomorrow should be a complete overhaul of the Ex, vacuum and a wash top to bottom. Man is she a dirty girl at the moment... |
(Post 16527508)
Wow, 30 X 60. Just imagine how much crap I could accumulate with a shop like that !!!:)
it fills up too fast, i suggest 100 x 60 for a good start `` |
Originally Posted by CharlyG
(Post 16528468)
Just ordered RAS on Amazon....I didn't do it to it, but for it! The do it will come in a few days!
:-drink |
Originally Posted by hav24wheel
(Post 16531932)
Clean up them hoses!!! That's looks horrible. Here's how I did mine....
http://i1257.photobucket.com/albums/...2657E0428B.jpg |
Washed the Ex, cleaned the coolant filter (didn't need it), checked all the fluids, hooked up the camper and it is waiting for Thursday to tow to the beach for the long weekend.
(Post 16532546)
Yes, I am in the process of doing just that. Since the 1/2 inch lines seem to kink much easier, I had to run the right side line in a bit of a loop after the reduction to 3/8.
On another note, anyone have any experience with trans codes?? https://www.ford-trucks.com/forums/1...rong-here.html |
I hate drum brakes
I put on my new rotors, pads and power stop calipers yesterday. I could not get the parking brake adjusting screw to back off. It took me five hours to do the first side and less than an hour for the second. I still need to bleed them. I hope I can get done tonight. Did I mention I hate drum brakes?
I also tried to find the 1/2 to 3/8 fittings to install my 6.0 transmission cooler with no luck. |
Just had the cooling system flushed this morning. The only unknown left is the tranny, but the oil looks good, the outside is clean, and the oil doesn't smell burnt. I thought I'd wait to get the SCT tune before evaluating the shifting, etc.
Originally Posted by pkthomas
(Post 16533419)
(Post 16533419)
(Post 16533419)
I also tried to find the 1/2 to 3/8 fittings to install my 6.0 transmission cooler with no luck. I found mine at Home Depot, the best I could do locally. I had to do it with 2 pieces ( at Lowes it would have taken 3 pieces ) like Dave suggested. The 1/2 inch was a female that threaded onto the 3/8 male. Sorry.... I forget what size the pipe thread was. I couldn't find adapters individually on Amazon when I ordered the cooler. |
(Post 16533647)
