My wife has given her 07 Mariner AWD very high marks for its performance in this winter's snow. She's really happy with the little thing and, consequently, I'm happy (since she isn't crabbing about it).
On the other hand, since I'm driving the old Conturd that used to be her daily driver, I'm ready for a 4WD/AWD of my own, maybe in an F250. |
Originally Posted by projectSHO89
(Post 9921118)
Originally Posted by wptski
(Post 9921385)
The way some talk, a Escape is as good as 4x4 F250.
(Post 9793208)
I had a '73 Blazer with 11x15s Dick Cepec(spell check) Armstrong Tru-Tracs that could run down to 5psi.
You have a open differential, front and rear. The AWD term is the most misused term in the auto industry. The same exact system is used in the Edge, Fusion and Escape but the emblem on my Escape shows 4WD but the other are tagged as AWD. Even the Ford Manuals refer use both terms because they are both the same. Regardless of driving conditions, every time one leaves from a dead stop, you get rear wheel torque. I use a Scanguage-II coded to monitor rear wheel torque. I have never seen more than 35% rear wheel torque even when floored on snow with the traction control ON or OFF. I have yet to see the so-called increased rear wheel torque with front slippage. In order to be called a true AWD, you need a clutch pack at every wheel. The Acura SH-AWD has a clutch at both rear wheels. I've discussed this in other forums before but it that Ford seems to think that they can use the AWD term because of the added traction control. The proper term would be A4WD for automatic 4WD as that's all it is. |
Originally Posted by danmansjimmy
(Post 9924739)
makes no sense, so because acura made a different setup for awd, that makes it a rule for must be awd? Awd was around before '04 when they started to manufacture the sh-awd. also that setup allows for a max of 40% rear wheel torque and that on the RL model. In all others its only 30%. at the setup was designed for cars for performance and cornering not plowing through the snow
The Escape is marketed as 4WD and although the Edge, Fusion, etc. system is exactly the same, it's refered to as AWD. The shop manuals toss the two terms back/forth. At FordVehicles.com there was a selectable moving graphic of a AWD Fusion. You could select one of the 3/4 driving conditions and it showed power being deverted to the wheel(s). One was a dry "S" road and it showed power being deverted side to side. This system doesn't devert power from side to side only back to front. I guess that's why Ford pulled that graphic as it was totally wrong. AWD stands for All Wheel Drive, correct? The standard open differential will split the power between each wheel providing they both have traction otherwise the one with the least amount gets the power. The same goes for 4WD, that's why it's wise to get a LSD or locker if available. I know that they have traction control now and I "think" that's where they thought that they could now use the AWD term. Above 62mph, TC doesn't use the ABS function or braking the spinning wheel. Here's an interesting video about 4WD/AWD systems although the Ford system isn't tested: 4WD/AWD |
I knew I should of bought a Subaru, damn!
Originally Posted by tonyford
(Post 9930621)
my wife's mariner dose great in the snow it is a little weard going around a corner the rear end will slide around untill the 4wd kicks in but it hasn't failed us yet. deffentaly not a true 4x4 but in the show it works just fine.
Originally Posted by cooljman1
(Post 9933743)
Well, at least I'm not alone with having the rear end coming around on me! |
x3 mine does it to! I had a 97 Explorer awd that did have the rear traction loc not sure about the front and it was a tank in deep snow.My 01 Escape goes just as will except for the turns and the rear sliding.But its great in the snow.I don't use the 4x4 that much mostly in the driveway or parking lot just to use it about every month.
Originally Posted by bmuhlbach
(Post 9934699)
Not to go off on a tangent, but I think there are many people who think 4Wheel Drive is 4 Wheel Stop. Just because they can GO in the snow does not mean they can stop any quicker than anyone else or any other vehicle. Some drivers of 4WD or AWD vehicles get over confident and this is what causes accidents.
